ADV7619 + analog input question
Question asked by Dvido on Oct 30, 2012
Latest reply on Nov 1, 2012 by Dvido
I need to build a setup with 2 HDMI 1.4 inputs and 1 analog video input. For the HDMI part I found that ADV7619 seems to fit my requirements but there is something unclear and I can't find the answer in the datasheet - does it support 2 simultaneous HDMI inputs, 24 bit each? Or does it support only 2 multiplexed inputs meaning that it will stream only one of them?
Another question is about an analog video Rx IC - I need something that will support as many different formats as possible but at low cost. I found ADV7604 which seems to be fine but it also has HDMI inputs (which I can't use because they don't support HDMI 1.4). Can you recommend such an IC?
For both of the above, is there a dev. board with HSMC connector that I can purchase?
Thank you,
David
