Persistent file storage in BF537e
Question asked by samiksha on Oct 29, 2012
Latest reply on Nov 4, 2012 by Aaronwu
I am using CM-BF537e on Bluetechnix Eval board.
I want to enable the JFFS2 so that I get a persistent file storage.
I am following the website
http://docs.blackfin.uclinux.org/doku.php?id=linux-kernel:jffs
And have done all the settings accordingly in the file.
But there is no /flash folder created when I compile the kernel romfs folder and when I load the uImage.ext2 on the core, the
following error occurs:
## Booting kernel from Legacy Image at 01000000 ...
   Image Name:   Linux Kernel and ext2
   Created:      2012-10-26  16:10:04 UTC
   Image Type:   Blackfin Linux Kernel Image (gzip compressed)
   Data Size:    3003380 Bytes = 2.9 MiB
   Load Address: 00100000
   Entry Point:  002bd6dc
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
Starting Kernel at = 002bd6dc
Linux version 2.6.34.7-ADI-2010R1-svn4647 (engsg@beryl) (gcc version 4.3.5 (ADI/svn-4154) ) #36 Fri Oct 26 17:09:42 BST 2012
register early platform devices
bootconsole [early_shadow0] enabled
bootconsole [early_BFuart0] enabled
early printk enabled on early_BFuart0
Found mtd parition at 0x002d1000, (len=0x800000), moving to 0x01600000
Board Memory: 32MB
Kernel Managed Memory: 32MB
Memory map:
  fixedcode = 0x00000400-0x00000490
  text      = 0x00100000-0x0022c738
  rodata    = 0x0022c738-0x0028bfac
  bss       = 0x0028c000-0x0029ce20
  data      = 0x0029ce20-0x002b2000
    stack   = 0x002b0000-0x002b2000
  init      = 0x002b2000-0x002d1000
  available = 0x002d1000-0x01600000
  rootfs    = 0x01600000-0x01e00000
  DMA Zone  = 0x01e00000-0x02000000
Hardware Trace Active and Enabled
Boot Mode: 1
Blackfin support (C) 2004-2010 Analog Devices, Inc.
Compiled for ADSP-BF537 Rev 0.2
Blackfin Linux support by http://blackfin.uclinux.org/
Processor Speed: 500 MHz core clock and 100 MHz System Clock
NOMPU: setting up cplb tables
Instruction Cache Enabled for CPU0
  External memory: cacheable in instruction cache
Data Cache Enabled for CPU0
  External memory: cacheable (write-through) in data cache
Built 1 zonelists in Zone order, mobility grouping off.  Total pages: 5588
Kernel command line: root=/dev/mtdblock3 rw clkin_hz=25000000 earlyprintk=serial,uart0,115200 console=ttyBF0,115200
PID hash table entries: 128 (order: -3, 512 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory available: 19356k/32768k RAM, (124k init code, 1201k kernel code, 535k data, 2048k dma, 9504k reserved)
Hierarchical RCU implementation.
NR_IRQS:138
Configuring Blackfin Priority Driven Interrupts
console [ttyBF0] enabled, bootconsole disabled
Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
Mount-cache hash table entries: 512
Blackfin Scratchpad data SRAM: 4 KB
Blackfin L1 Data A SRAM: 16 KB (16 KB free)
Blackfin L1 Data B SRAM: 16 KB (16 KB free)
Blackfin L1 Instruction SRAM: 48 KB (35 KB free)
NET: Registered protocol family 16
Blackfin DMA Controller
cm_bf537e_init(): registering device resources
bio: create slab <bio-0> at 0
bfin-spi bfin-spi.0: Blackfin on-chip SPI Controller Driver, Version 1.0, regs_base@ffc00500, dma channel@7
Switching to clocksource bfin_cs_cycles
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
JFFS2 version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
msgmni has been set to 37
io scheduler noop registered
io scheduler cfq registered (default)
bfin-dma: initialized
bfin-uart: Blackfin serial driver
bfin-uart.0: ttyBF0 at MMIO 0xffc00400 (irq = 18) is a BFIN-UART
brd: module loaded
loop: module loaded
physmap platform flash device: 00400000 at 20000000
physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank
Intel/Sharp Extended Query Table at 0x0031
Using buffer write method
cfi_cmdset_0001: Erase suspend on write enabled
RedBoot partition parsing not available
Using physmap partition information
Creating 3 MTD partitions on "physmap-flash.0":
0x000000000000-0x000000040000 : "bootloader(nor)"
0x000000040000-0x000000340000 : "linux kernel(nor)"
0x000000340000-0x000000400000 : "file system(nor)"
uclinux[mtd]: RAM probe address=0x1600000 size=0x800000
Creating 1 MTD partitions on "RAM":
0x000000000000-0x000000800000 : "ROMfs"
bfin_mii_bus: probed
bfin_mac: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, irq=-1, mdc_clk=2500000Hz(mdc_div=19)@sclk=100MHz)
bfin_mac bfin_mac.0: Blackfin on-chip Ethernet MAC driver, Version 1.1
i2c /dev entries driver
TCP cubic registered
dma_alloc_init: dma_page @ 0x009ca000 - 512 pages at 0x01e00000
VFS: Mounted root (ext2 filesystem) on device 31:3.
Freeing unused kernel memory: 124k freed
init: exec rc failed
init: Booting to single user mode
init: exec of single user shell failed
init: -/bin/sh exec failed
Also when I try to set and save the environment variables, it gives me the following errors:
bfin> set bootargs root=/dev/mtdblock3 rw clkin_hz=25000000 earlyprintk=serial,uart0,115200 console=ttyBF0,115200
bfin> saveenv
Saving Environment to Flash...
Error: start address not on sector boundary
Thanks and regards,
Samiksha
