Can't get past the early kernel prints...
Question asked by arad85 on Oct 27, 2012
Latest reply on Oct 29, 2012 by CraigG
I can't figure out what is wrong with my environment to get this to boot. I have an IP02 blackfin PABX and I'm trying to compile some code to run on it. The environment is the default switchfin environment available from switchfin.org. I compile everything with console UART support and have tried a number of methods of booting - but none get console output after the early printk has happened. I'm after the magic runes that will let me boot this kernel fully... Here is the console output:
U-Boot 2010.06 (ADI-2010R1-pre) (Jan 08 2011 - 14:09:20)
CPU:   ADSP bf532-0.5 (Detected Rev: 0.6) (spi flash boot)
Board: IPPBX IP0x
Clock: VCO: 400 MHz, Core: 400 MHz, System: 133.333 MHz
RAM:   64 MiB
NAND:  256 MiB
SF: Detected W25X40 with page size 256, total 512 KiB
In:    serial
Out:   serial
Err:   serial
Net:   dm9000
starting from spi flash
Hit any key to stop autoboot:  0
ip0x> printenv
bootargs=
bootdelay=3
baudrate=115200
loads_echo=1
autoload=no
preboot=echo starting from spi flash
rootpath=/romfs
hostname=IP0x
loadaddr=0x1000000
flashboot=bootm 0x20100000
ethact=dm9000
ethaddr=00:09:45:5A:1C:CC
eth1addr=00:09:45:5A:1C:CD
mtdparts=mtdparts=ip0x-nand:0x00800000(kernel),0x0f800000(fs)
serveraddr=00:0c:29:d7:0a:5a
filesize=6C0000
fileaddr=2000000
gatewayip=192.168.1.1
netmask=255.255.255.0
mtdids=nand0=ip0x-nand
partition=nand0,0
mtddevnum=0
mtddevname=kernel
autostart=yes
nandboot=run setbootargs; nand read.e 0x2000000 kernel; bootm 0x2000000
bootcmd=run nandboot
ipaddr=192.168.1.200
serverip=192.168.1.1
setbootargs=setenv bootargs ethaddr=$(ethaddr) ethaddr1=$(eth1addr) console=ttyBF0,115200 earlyprintk=serial,uart0,115200 root=/dev/mtdblock0 rw ${mtdparts}
stdin=serial
stdout=serial
stderr=serial
Environment size: 829/65532 bytes
ip0x> setenv bootargs console=serial,ttyBF0,115200   earlyprintk=serial,uart0,115200
ip0x> tftp uImage-2012-10-27-22-22
ERROR: resetting DM9000 -> not responding
dm9000 i/o: 0x20100000, id: 0x90000a46
DM9000: running in 16 bit mode
MAC: 00:09:45:5a:1c:cc
operating at 100M full duplex mode
Using dm9000 device
TFTP from server 192.168.1.1; our IP address is 192.168.1.200
Filename 'uImage-2012-10-27-22-22'.
Load address: 0x1000000
Loading: T #################################################################
done
Bytes transferred = 6815744 (680000 hex)
Automatic boot of image at addr 0x01000000 ...
## Booting kernel from Legacy Image at 01000000 ...
   Image Name:   Linux Kernel and ext2
   Image Type:   Blackfin Linux Kernel Image (gzip compressed)
   Data Size:    6707251 Bytes = 6.4 MiB
   Load Address: 00001000
   Entry Point:  0021430c
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
Starting Kernel at = 0021430c
Linux version 3.0.8-ADI-2011R1switchfin (andy@afin.home) (gcc version 4.3.5 (ADI-2011R1-RC4) ) #4 Sat Oct 27 22:14:31 BST 2012
register early platform devices
bootconsole [early_shadow0] enabled
bootconsole [early_BFuart0] enabled
early printk enabled on early_BFuart0
Found mtd parition at 0x0022b000, (len=0x1400000), moving to 0x02b00000
Board Memory: 64MB
Kernel Managed Memory: 64MB
Memory map:
  fixedcode = 0x00000400-0x00000490
  text      = 0x00001000-0x0017a370
  rodata    = 0x0017a370-0x001ea6d8
  bss       = 0x001eb000-0x001faff8
  data      = 0x001fb000-0x00210000
    stack   = 0x0020e000-0x00210000
  init      = 0x00210000-0x0022b000
  available = 0x0022b000-0x02b00000
  rootfs    = 0x02b00000-0x03f00000
  DMA Zone  = 0x03f00000-0x04000000
Hardware Trace active and enabled
Boot Mode: 6
Blackfin support (C) 2004-2010 Analog Devices, Inc.
Compiled for ADSP-BF532 Rev any, running on 0.6
Blackfin Linux support by http://blackfin.uclinux.org/
Processor Speed: 400 MHz core clock and 133 MHz System Clock
NOMPU: setting up cplb tables
Instruction Cache Enabled for CPU0
  External memory: cacheable in instruction cache
Data Cache Enabled for CPU0
  External memory: cacheable (write-back) in data cache
Built 1 zonelists in Zone order, mobility grouping off.  Total pages: 10922
Kernel command line: console=serial,ttyBF0,115200 earlyprintk=serial,uart0,115200
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory available: 41204k/65536k RAM, (108k init code, 1508k kernel code, 600k data, 1024k dma, 612k reserved)
SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
NR_IRQS:81
Configuring Blackfin Priority Driven Interrupts
bfin-uart.0: No uart status IRQ specified
bfin-console: unable to probe bfin-uart early.
Calibrating delay loop... 792.57 BogoMIPS (lpj=1585152)
pid_max: default: 32768 minimum: 301
Security Framework initialized
Mount-cache hash table entries: 512
Blackfin Scratchpad data SRAM: 4 KB
Blackfin L1 Instruction SRAM: 32 KB (20 KB free)
NET: Registered protocol family 16
Blackfin DMA Controller
ip0x_init(): chip_id=627A50CB,dspid=E5040006
ip0x_init(): registering nand resources
ip0x_init(): registering platform devices
bio: create slab <bio-0> at 0
SCSI subsystem initialized
Switching to clocksource bfin_cs_cycles
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
msgmni has been set to 80
io scheduler noop registered
io scheduler cfq registered (default)
bfin-uart: Blackfin serial driver
bfin-uart bfin-uart.0: No uart status IRQ specified
bfin-uart: probe of bfin-uart.0 failed with error -2
brd: module loaded
uclinux[mtd]: RAM probe address=0x2b00000 size=0x1400000
Creating 1 MTD partitions on "RAM":
0x000000000000-0x000001400000 : "ROMfs"
Generic platform RAM MTD, (c) 2004 Simtec Electronics
NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bit)
Scanning device for bad blocks
Bad eraseblock 1353 at 0x00000a920000
tun: Universal TUN/TAP device driver, 1.6
tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
dm9000 Ethernet Driver, V1.31
eth0: dm9000b at 20100000,20100002 IRQ 48 MAC: 00:09:45:5a:1c:cc (chip)
dm9000 dm9000.1: eth%d: Invalid ethernet MAC address. Please set using ifconfig
eth1: dm9000b at 20200000,20200002 IRQ 47 MAC: 56:18:33:3c:33:bb (random)
bfin-wdt: initialized: timeout=20 sec (nowayout=0)
TCP cubic registered
802.1Q VLAN Support v1.8
turn off boot console early_BFuart0
The relevant bit of the config file at: /home/andy/switchfin/build_ip04/blackfin-linux-dist/linux-2.6.x
is:
# Character devices
# CONFIG_VT is not set
CONFIG_UNIX98_PTYS=y
# CONFIG_DEVPTS_MULTIPLE_INSTANCES is not set
# CONFIG_LEGACY_PTYS is not set
# CONFIG_BFIN_JTAG_COMM is not set
# CONFIG_SERIAL_NONSTANDARD is not set
# CONFIG_N_GSM is not set
# CONFIG_TRACE_SINK is not set
CONFIG_BFIN_DMA_INTERFACE=m
# CONFIG_BFIN_PPI is not set
# CONFIG_BFIN_SIMPLE_TIMER is not set
# CONFIG_BFIN_SPORT is not set
# CONFIG_DEVKMEM is not set
# Serial drivers
# CONFIG_SERIAL_8250 is not set
# Non-8250 serial port support
# CONFIG_SERIAL_MAX3100 is not set
# CONFIG_SERIAL_MAX3107 is not set
CONFIG_SERIAL_BFIN=y
CONFIG_SERIAL_BFIN_CONSOLE=y
CONFIG_SERIAL_BFIN_DMA=y
# CONFIG_SERIAL_BFIN_PIO is not set
CONFIG_SERIAL_BFIN_UART0=y
# CONFIG_BFIN_UART0_CTSRTS is not set
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
# CONFIG_SERIAL_BFIN_SPORT is not set
# CONFIG_SERIAL_TIMBERDALE is not set
# CONFIG_SERIAL_ALTERA_JTAGUART is not set
# CONFIG_SERIAL_ALTERA_UART is not set
# CONFIG_SERIAL_XILINX_PS_UART is not set
CONFIG_TTY_PRINTK=y
# CONFIG_HVC_BFIN_JTAG is not set
# CONFIG_IPMI_HANDLER is not set
CONFIG_HW_RANDOM=y
# CONFIG_HW_RANDOM_TIMERIOMEM is not set
# CONFIG_R3964 is not set
# CONFIG_RAW_DRIVER is not set
# CONFIG_TCG_TPM is not set
# CONFIG_RAMOOPS is not set
# CONFIG_I2C is not set
CONFIG_SPI=y
CONFIG_SPI_MASTER=y
How do I get it to show the complete console output?
