1 catastrophic error detected in the compilation of ".\src\ltp.c".
Question asked by jjtdragon on Oct 23, 2012
Latest reply on Oct 30, 2012 by CraigG
Visual DSP++ asked me to submit this bug report. I thought I would be a nice guy and comply.
At end of source: : internal error: Uncaught exception Assertion failed raised
          at ../../../bril/optimiser/colour.c:5076 (in pass
          register_allocation:1 during compilation of _pitch_xcorr). Please
          submit a bug report with this message, the command line used, type
          of machine and the output of the compiler when you add -ED -v to the
          command line. Please also send us the pre-processed file that is
          generated by the -ED option (the file generated is named
          <original_filename>.i)
It says include this message! Now I have.
Command line:
C:/Program\ Files/Analog\ Devices/VisualDSP\ 5.0/ccblkfn.exe -c .\src\ltp.c -file-attr ProjectName=Speex -O -Ov100 -g -save-temps -path-output .\Debug -structs-do-not-overlap -no-multiline -I ..\speex\inc -I ..\MHAL_DSP\Utilities -I ..\MHAL_DSP\Comm -I ..\MHAL_DSP\Tailor -I ..\MHAL_DSP\Drivers -double-size-32 -decls-strong -warn-protos -si-revision 0.5 -proc ADSP-BF561 -o .\Debug\ltp.doj -MM
Machine: Windows 32 Core 2 Duo
VisualDSP++ 5.0 Update 10.1
User Interface Driver : Blackfin version 8.1.10.4 (Jul 22 2011 14:01:31)
                 BUILD-B-REL-VDSP5_0A-20110722_1251
  Copyright (c) 1997-2011 Analog Devices, Inc.
  Copyright (c) 1997-1999 Edinburgh Portable Compilers, Ltd.
        mkdir C:\Tmp\acc06741983000 >>nul 2>&1
        "C:\Program Files\Analog Devices\VisualDSP 5.0\ccblkfn.exe" --main --generate_asm --prelink --path_comp "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\etc\compiler.exe" --opts_comp "--target=ADSP-BF532 --TLI=-is_multicore,-multicore_mmr=0xFFE00000 --TLI=-multicore_sram_a=0xFF800000 --TLI=-multicore_sram_b=0xFF400000 --requested_architecture ADSP-BF561 -D__SILICON_REVISION__=0x5 --silicon_revision_str 0.5 --no_remove_unneeded_entities --warn_protos --preprocess --version -D_ADI_LIBIO --TLI -si-revision=0x5,-workaround=12,-workaround=15,-workaround=19,-workaround=25,-workaround=31,-workaround=44,-workaround=46,-workaround=47,-workaround=49,-workaround=48,-workaround=51,-O,-force_link,-auto_attrs,-opt_speed_vs_size=100,-generate_debug,-struct_copies_use_memcpy,-convert_commons,-no_zero_loop_counters,-use_bss,-reservable=m3" --display_error_number --diag_remark 174,177,550,1124 --restrict --no_pch_messages --path_asm "C:\Program Files\Analog Devices\VisualDSP 5.0\easmblkfn.exe" --opts_asm "-proc ADSP-BF561 -stallcheck=none -W5500 -W5508 -si-revision 0.5 -D__WORKAROUND_TESTSET_ALIGN -D__WORKAROUND_SPECULATIVE_LOADS -D__WORKAROUND_AVOID_LDF_BLOCK_BOUNDARIES -D__WORKAROUND_STALLED_MMR_WRITE_283 -D__WORKAROUND_SYNC_LOOP_ANOM_312 -D__WORKAROUND_AVOID_QUICK_RTS_371 -D__WORKAROUND_05000428 -D__WORKAROUND_05000426 -D__WORKAROUND_05000412 -D__WORKAROUND_05000443 -D__WORKAROUND_05000477 -D__WORKAROUNDS_ENABLED -D__WORKAROUND_FLAGS_MMR_ANOM_323=1 -I ..\speex\inc -I ..\MHAL_DSP\Utilities -I ..\MHAL_DSP\Comm -I ..\MHAL_DSP\Tailor -I ..\MHAL_DSP\Drivers -file-attr ProjectName=Speex" --path_pl "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\etc\prelinker.exe" --opts_pl "-t -V" --path_ipa "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\etc\ipa.exe" --path_link "C:\Program Files\Analog Devices\VisualDSP 5.0\linker.exe" --opts_link "-proc ADSP-BF561 -si-revision 0.5 -MD__WORKAROUND_TESTSET_ALIGN -MD__WORKAROUND_SPECULATIVE_LOADS -MD__WORKAROUND_AVOID_LDF_BLOCK_BOUNDARIES -MD__WORKAROUND_STALLED_MMR_WRITE_283 -MD__WORKAROUND_SYNC_LOOP_ANOM_312 -MD__WORKAROUND_AVOID_QUICK_RTS_371 -MD__WORKAROUND_05000428 -MD__WORKAROUND_05000426 -MD__WORKAROUND_05000412 -MD__WORKAROUND_05000443 -MD__WORKAROUND_05000477 -MD__WORKAROUNDS_ENABLED -jcs2l \"-IC:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\lib\bf561_rev_0.5\" -version -MD_ADI_LIBIO -I ..\speex\inc -I ..\MHAL_DSP\Utilities -I ..\MHAL_DSP\Comm -I ..\MHAL_DSP\Tailor -I ..\MHAL_DSP\Drivers -I \"C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\"" --TLI -pgo_session --TLI default --opts_driver "-c -file-attr ProjectName=Speex -O -Ov100 -g -save-temps -path-output .\Debug -structs-do-not-overlap -no-multiline -I ../speex/inc -I ../MHAL_DSP/Utilities -I ../MHAL_DSP/Comm -I ../MHAL_DSP/Tailor -I ../MHAL_DSP/Drivers -double-size-32 -decls-strong -warn-protos -si-revision 0.5 -proc ADSP-BF561 -o .Debugltp.doj -MM -ED -v" --assert "system(embedded)" --assert "machine(adspblkfn)" --assert "cpu(adspblkfn)" --assert "compiler(ccblkfn)" -D__ECC__=1 -D_LANGUAGE_C=1 -D__ANALOG_EXTENSIONS__=1 -D__FIXED_POINT_ALLOWED=1 -D__DOUBLES_ARE_FLOATS__=1 -D__ADSPBLACKFIN__=1 -D__ADSPLPBLACKFIN__=1 -D__ADSPBF561__=1 -D__ADSPBF56x__=1 -D__ADSPBF561_FAMILY__=1 -D__NUM_CORES__=2 -D__VISUALDSPVERSION__=0x05000a00 -D__WORKAROUND_FLAGS_MMR_ANOM_323=1 -I..\speex\inc -I..\MHAL_DSP\Utilities -I..\MHAL_DSP\Comm -I..\MHAL_DSP\Tailor -I..\MHAL_DSP\Drivers "-IC:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include" -D__WORKAROUND_TESTSET_ALIGN -D__WORKAROUND_SPECULATIVE_LOADS -D__WORKAROUND_AVOID_LDF_BLOCK_BOUNDARIES -D__WORKAROUND_STALLED_MMR_WRITE_283 -D__WORKAROUND_SYNC_LOOP_ANOM_312 --list_init 48=-no-anomaly-detect;05000371 -D__WORKAROUND_AVOID_QUICK_RTS_371 --list_init 48=-no-anomaly-detect;05000428 -D__WORKAROUND_05000428 -D__WORKAROUND_05000426 -D__WORKAROUND_05000412 -D__WORKAROUND_05000443 -D__WORKAROUND_05000477 -D__WORKAROUNDS_ENABLED -c -k --no_gnu_multiline_strings --double=32 -MM --preprocessor_files -v --pch_messages --c --analog_mode --signed_chars --no_preproc_only --set-file-attr ProjectName=Speex --output_dir .\Debug -o .\Debug\.Debugltp.doj .\src\ltp.c
        "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\etc\compiler.exe" --target=ADSP-BF532 --TLI=-is_multicore,-multicore_mmr=0xFFE00000 --TLI=-multicore_sram_a=0xFF800000 --TLI=-multicore_sram_b=0xFF400000 --requested_architecture ADSP-BF561 -D__SILICON_REVISION__=0x5 --silicon_revision_str 0.5 --no_remove_unneeded_entities --warn_protos --preprocess --version -D_ADI_LIBIO --TLI -si-revision=0x5,-workaround=12,-workaround=15,-workaround=19,-workaround=25,-workaround=31,-workaround=44,-workaround=46,-workaround=47,-workaround=49,-workaround=48,-workaround=51,-O,-force_link,-auto_attrs,-opt_speed_vs_size=100,-generate_debug,-struct_copies_use_memcpy,-convert_commons,-no_zero_loop_counters,-use_bss,-reservable=m3 --display_error_number --diag_remark 174,177,550,1124 --restrict --no_pch_messages --TLI -pgo_session --TLI default --assert "system(embedded)" --assert "machine(adspblkfn)" --assert "cpu(adspblkfn)" --assert "compiler(ccblkfn)" -D__ECC__=1 -D_LANGUAGE_C=1 -D__ANALOG_EXTENSIONS__=1 -D__FIXED_POINT_ALLOWED=1 -D__DOUBLES_ARE_FLOATS__=1 -D__ADSPBLACKFIN__=1 -D__ADSPLPBLACKFIN__=1 -D__ADSPBF561__=1 -D__ADSPBF56x__=1 -D__ADSPBF561_FAMILY__=1 -D__NUM_CORES__=2 -D__VISUALDSPVERSION__=0x05000a00 -D__WORKAROUND_FLAGS_MMR_ANOM_323=1 -I..\speex\inc -I..\MHAL_DSP\Utilities -I..\MHAL_DSP\Comm -I..\MHAL_DSP\Tailor -I..\MHAL_DSP\Drivers "-IC:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include" -D__WORKAROUND_TESTSET_ALIGN -D__WORKAROUND_SPECULATIVE_LOADS -D__WORKAROUND_AVOID_LDF_BLOCK_BOUNDARIES -D__WORKAROUND_STALLED_MMR_WRITE_283 -D__WORKAROUND_SYNC_LOOP_ANOM_312 -D__WORKAROUND_AVOID_QUICK_RTS_371 -D__WORKAROUND_05000428 -D__WORKAROUND_05000426 -D__WORKAROUND_05000412 -D__WORKAROUND_05000443 -D__WORKAROUND_05000477 -D__WORKAROUNDS_ENABLED --no_gnu_multiline_strings --double 32 --dependencies --pch_messages --c --analog_mode --signed_chars --no_preproc_only --set-file-attr ProjectName=Speex --depend_target .\Debug\.Debugltp.doj --no_preproc_only --driver_options "-c -file-attr ProjectName=Speex -O -Ov100 -g -save-temps -path-output .\Debug -structs-do-not-overlap -no-multiline -I ../speex/inc -I ../MHAL_DSP/Utilities -I ../MHAL_DSP/Comm -I ../MHAL_DSP/Tailor -I ../MHAL_DSP/Drivers -double-size-32 -decls-strong -warn-protos -si-revision 0.5 -proc ADSP-BF561 -o .Debugltp.doj -MM -ED -v" --gen_asm_file_name .\Debug\ltp.s --preprocessor_output .\Debug\ltp.i .\src\ltp.c
"Debug\.Debugltp.doj": "src\ltp.c"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\math.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\yvals.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\ymath.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\math_bf.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\fract_typedef.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\fract_math.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\ccblkfn.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\stdlib.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\stdlib_bf.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\builtins.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\sys\builtins_support.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\fr2x16_typedef.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\r2x16_typedef.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\raw_typedef.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\sys\anomaly_macros_rtl.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\sys\mc_typedef.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\cdefBF561.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\defBF561.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\def_LPBlackfin.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\cdef_LPBlackfin.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\fr2x16_math.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\fr2x16_base.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\r2x16_base.h"
"Debug\.Debugltp.doj": "..\speex\inc\ltp.h"
"Debug\.Debugltp.doj": "..\speex\inc\speex\speex_bits.h"
"Debug\.Debugltp.doj": "..\speex\inc\arch.h"
"Debug\.Debugltp.doj": "..\speex\inc\speex\speex_types.h"
"Debug\.Debugltp.doj": "..\speex\inc\speex\speex_config_types.h"
"Debug\.Debugltp.doj": "..\speex\inc\fixed_generic.h"
"Debug\.Debugltp.doj": "..\speex\inc\fixed_bfin.h"
"Debug\.Debugltp.doj": "..\speex\inc\stack_alloc.h"
"Debug\.Debugltp.doj": "..\speex\inc\filters.h"
"Debug\.Debugltp.doj": "..\speex\inc\math_approx.h"
"Debug\.Debugltp.doj": "..\speex\inc\os_support.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\string.h"
"Debug\.Debugltp.doj": "C:\Program Files\Analog Devices\VisualDSP 5.0\Blackfin\include\stdio.h"
"Debug\.Debugltp.doj": "..\speex\inc\ltp_bfin.h"
C/C++ Compiler : Blackfin version 8.1.10.4 (Jul 22 2011 14:01:28)
  Copyright (c) 1998-2007 Edison Design Group, Inc.
Edison Design Group C/C++ Front End, version 3.10 (Jul 22 2011 13:46:54)
Copyright 1988-2007 Edison Design Group, Inc.
Compilation aborted.
cc3089: fatal error: Compilation failed
        del .\Debug\ltp.sbn >>nul 2>&1
        del .\Debug\ltp.s >>nul 2>&1
        rd /q C:\Tmp\acc06741983000 >>nul 2>&1
