Uart write and read Problem
Question asked by barreh.walid.EBSYS on Oct 23, 2012
Latest reply on Oct 31, 2012 by jobo23
Hi
I tried to integrate the uart driver with Video decoder & encoder driver, but uart write function is not working .
We used the following code:
void main(void)
/* Initialize ADI components */
    adi_initComponents();
    /* Configure software switches on ADSP-BF609 EZ-Board */
     ConfigSoftSwitches_BF609();
    /* Configure system - terminate configuration process on error */
    do
        /* Initialize OSAL */
        if (adi_osal_Init() != ADI_OSAL_SUCCESS)
            DEBUG_MSG1("Failed to Initialize OSAL\n");
            Result = FAILURE;
                   break;
        /* Initialize Power service */
            if(adi_pwr_Init(CLKIN, CORE_MAX, SYSCLK_MAX, VCO_MIN) != ADI_PWR_SUCCESS)
                REPORT_ERROR("Failed to initialize power service \n");
                return FAILED;
        /* Initialize GPIO service with number of callbacks required */
        if(adi_gpio_Init(GPIOCallbackMem, GPIO_MEM_SIZE, &NumCallbacks) != ADI_GPIO_SUCCESS)
            DEBUG_MSG1 ("Failed to configure GPIO Service\n");
            Result = FAILURE;
                  break;
/* Initialize ADV7511 Encoder */
               Result = (uint32_t) InitEncAdv7511();
        if (Result)
            DEBUG_MSG2("Failed to initialize ADV7511 video encoder", Result);
            break;
  /* Initialize ADV7842 Decoder */
        Result = (uint32_t) InitDecAdv7842();
        if (Result)
            DEBUG_MSG2("Failed to initialize ADV7842 video decoder", Result);
                   break;
         * Initialize UART
        /* Open UART driver */
        if((eResult = adi_uart_Open(UART_DEVICE_NUM,
                                     ADI_UART_DIR_BIDIRECTION,
                                     gUARTMemory,
                                     ADI_UART_BIDIR_DMA_MEMORY_SIZE,
                                     &ghUART)) != ADI_UART_SUCCESS)
                  REPORT_ERROR("Could not open UART Device 0x%08X \n", eResult);
                  //return FAILED;
                  break;
        /* Set the UART Mode */
        if((eResult = adi_uart_SetMode(ghUART,
                                        ADI_UART_MODE_UART
                  REPORT_ERROR("Could not set the Mode 0x%08X \n", eResult);
                  //return FAILED;
                  break;
        /* Set UART Baud Rate */
        if((eResult = adi_uart_SetBaudRate(ghUART,
        BAUD_RATE
                  REPORT_ERROR("Could not set the Baud Rate 0x%08X \n", eResult);
                  //return FAILED;
                  break;
        /* Set number of stop bits */
        if((eResult = adi_uart_SetNumStopBits(ghUART,
                                                ADI_UART_ONE_STOPBIT
                  REPORT_ERROR("Could not set the stop bits 0x%08X \n", eResult);
                  //return FAILED;
                  break;
        if((eResult = adi_uart_SetWordLen(ghUART,
                                              ADI_UART_WORDLEN_8BITS
                  REPORT_ERROR("Could not set word length 0x%08X \n", eResult);
                  //return FAILED;
                  break;
       while(1){
            RxBuffer[0] = '0';
                      RxBuffer[1] = '1';
                      RxBuffer[2] = '3';
           if((eResult = adi_uart_Write(ghUART,&RxBuffer[0],/*nTxSize*/3)) != ADI_UART_SUCCESS)
                            REPORT_ERROR("Error  0x%08X \n", eResult);
                            //return FAILED;
                            break;
THANKS...
