h.264 encoder lost half of image, strange problem
Question asked by Hong on Oct 15, 2012
Latest reply on Oct 31, 2012 by Hong
Hi, the h.264 baseline encoder SDK produces strange result as the following sample. I have no idea how this happened..
I checked the setting and found that this phenomenon appeared when pvc->scaling was set to H_V_HALF. If I set pvc->scaling = 0, it works right.
My initial code is as follows,
init_encoder_settings_cmos_vga
// Interface for CMOS sensors
void init_encoder_settings_cmos_vga(vidcodec_t *pvc)
          pvc->bitrate = 1000000;
          pvc->frame_slice_num = 1;
          pvc->disable_deblocking_filter_idc = 2;
          pvc->slice_alpha_c0_offset_div2 = 0;
          pvc->slice_beta_offset_div2 = 0;
          pvc->frame_type = -2;
          pvc->search_complexity  = 0x6A132297;
          pvc->sc_detect_flag = 0x10038932;
          pvc->rc_control = 0x0A42ccf5;
          pvc->pos_x = 0;
          pvc->pos_y = 0;
          pvc->fixedQP = 0;
          pvc->splitframe = 0;
          pvc->field_pic_flag = 0;
          pvc->profile_idc = BASELINE_PROFILE;
          pvc->ccir_deinterlace = 1;
          pvc->chk_for_dma_err = 0;
          pvc->bframecnt = 0;
          pvc->mbquant_flag = 0;
          pvc->cabac_flag = 0;
          pvc->enable_constant_pic_id = 0;
          pvc->enable_chksum = 0;
          pvc->enable_aspect_ratio = 0;
          pvc->windowpos = 0;
          pvc->pixel_aspect_x = -1;
          pvc->pixel_aspect_y = -1;
          pvc->is_preproc_api_used = 0;
          pvc->enable_idr = 1;
          // Output format
          pvc->width  = 320;
          pvc->height = 240;
          pvc->framerate = 5;
          pvc->keyframe_dist = pvc->framerate-1;
          pvc->video_standard = RAW422_PROG;
          // VGA input
          pvc->vid_capture_width = 640;
          pvc->vid_capture_height = 480;
          pvc->vid_capture_frate = 5;
          pvc->color_format = CCIR422;
          pvc->scaling = H_V_HALF;
#define DEST_DMA_CONFIG_OFFSET  0x08
#define DEST_DMA_DESC_OFFSET    0x20
#define DEST_DMA_IRQ_OFFSET     0x28
#define SRC_DMA_CONFIG_OFFSET   0x48
#define SRC_DMA_DESC_OFFSET     0x60
#define SRC_DMA_IRQ_OFFSET      0x68
          // MDMA0
          pvc->MDMA_D0CFG        = MDMA_D0_NEXT_DESC_PTR + (DEST_DMA_CONFIG_OFFSET);
          pvc->MDMA_D0DSC        = MDMA_D0_NEXT_DESC_PTR + (DEST_DMA_DESC_OFFSET);
          pvc->MDMA_S0CFG        = MDMA_D0_NEXT_DESC_PTR + (SRC_DMA_CONFIG_OFFSET);
          pvc->MDMA_S0DSC        = MDMA_D0_NEXT_DESC_PTR + (SRC_DMA_DESC_OFFSET);
          pvc->MDMAD0_IRQ_STATUS = MDMA_D0_NEXT_DESC_PTR + (DEST_DMA_IRQ_OFFSET);
          pvc->MDMAS0_IRQ_STATUS = MDMA_D0_NEXT_DESC_PTR + (SRC_DMA_IRQ_OFFSET);
Thanks for any advice,
B.R.
Hong.
