Hi
i am using 20 MHz external CLK for AD9957 PLL input, but it is not locking for frequency 800 MHz.it gives a 20-30 MHz wide signal at pin no 55. centered around 320 MHz.(pll loop filter BW=2.5 MHz,VCO=4)when i change the VCO from 4 to 5,it results increase in current & same spectrum shifted to around 400 MHz,pl suggest why PLL is not locking.
its ref clk circuit is working by verifying /8 output frequency & /4 output at pin no 55.
one more observation when loop filter is designed for 50 KHz ,the devices does not draw current.
Are you using the AD9957 evaluation board or not? If so, the evaluation board does not populate the PLL loop filter components. I have attached an excel file to help calculate the values for the desired conditions. Note, 50Khz loop bandwidth is probably too narrow. The internal VCO in the AD9957 is a ring oscillator type. The close in phase noise of this type vs LC is typically higher. So, if you have a REF CLK source with good in close phase noise performance, I would suggest running the loop bandwidth around 1Mhz verses 50KHz. That should improve the overall close in phase noise performance.
