special macros
Question asked by mohamed on Jul 23, 2009
Latest reply on Jul 23, 2009 by AndyC
i have used these two macros for setting ang clearing bits for certian registers and they worked good with me and i have tested there work with many registers
#define SYSREG_CLR(sysreg,bit) __builtin_sysreg_write(sysreg, __builtin_sysreg_read(sysreg)&~bit)   //macro used to clear the bits
#define SYSREG_SET(sysreg,bit) __builtin_sysreg_write(sysreg, __builtin_sysreg_read(sysreg)|~bit)   //macro used to set bits
the problems appeared when i used them in a certain application where i need to access a certain interrupt registers such as  IMASKH
and when  write the name of the bit according to the hardware refrence of the ADSP_TS201 the compiler told me that they are unidentified
and i have inclued the important eader files such as  defts201.h    builtins.h   sysreg.h
ex:
SYSREG_SET(__IMASKH,IMASKH_INT_TIMEROHP)
or when i tried to test the value of a bit in ILATH register it also give me an error
ex:
int x;
x= __builtin_sysreg_read(__ILATH);
x&= ILATH_INT_TIMER0HP;
it also till be that it is unidentified
and i used these syntax many times with other registers and other bits as there name is listed in the hardware refernce and no error occured
please try to help me
