SPI Slave Problem with ADSP 21469
Question asked by Hfuhrhurr on Sep 25, 2012
Latest reply on Sep 26, 2012 by Hfuhrhurr
I have a problem with transferring data from a Stellaris ARM CPU to the 21469 over SPI. The DSP is configured as slave.
I can successfully boot the DSP as a slave from the CPU, so in principle, the connection works fine.
However, normal data transfer after booting the DSP does not work.
I boiled down my code to a small test program just to check SPI.
Here it is
 * main.c
#include <sysreg.h>
#include "defines.h"
#include <sru21469.h>
#include<cs_macros.h>
void Receive_data(int i);
int destination[16];
int dma_done = 0;
void main()
    ADSP_2146X_PLL_Init_INDIV_STEP_NOT_REQUIRED(36,2,0,2,3);
   *pSPICTL = 0;
   *pSPIDMAC = 0;
   *pSPIBAUD = 0;
   *pSPIFLG = 0;
   interrupt(SIG_SPIH, Receive_data);
   *pIISPI = (int)destination;
   *pIMSPI = 1;
   *pCSPI = 16;
   *pSPICTL = RXFLSH | TXFLSH;
   *pSPIDMAC = FIFOFLSH;
   *pSPICTL =  MSBF| CPHASE| CLKPL| SPIEN | WL16 | TIMOD2 ;
   *pSPIDMAC = SPIDEN | SPIRCV | INTEN;
   while(1)
      asm("nop;");
   dma_done = 1;
From the CPU, I send data by manually controlling the slave select line to be able to control the timing in detail.
With a scope, I recorded the signals data, clk, slave select (from top to bottom),
I don't see anything wrong with this, however, the data are not transferred.
The weirdest thing is, that yesterday, 3 or 4 times it worked, today, I can not reproduce that. Booting over SPI still works.
SPI rate is 50kHz, currently, but I also tested values up to 500kHz.
What do I miss?
Rainer
