sending word with SPI to codec
Question asked by savinat on Jul 16, 2009
Latest reply on Jan 22, 2010 by jeyanthi.jegadeesan
Hi ,
I have to send a word with SPI on ADSP21364 to ADAU1361. So i read the example in the visual dsp ++ wich is  using ADSP21364 and AD1835, but i think to do something similar. I don`t understand  what is the Delay(100) for; And this:  int configSize = sizeof (Config1835Param) / sizeof (int) ;
Can i use that example but withought reading from codec?
Bellow is the full example :
#include "tt.h"
#include "ad1835.h"
void SetupSPI1835(void);
void DisableSPI1835(void);
/* Setup the SPI pramaters here in a buffer first */
unsigned int Config1835Param [] = {
            WR | DACCTRL1 | DACI2S | DAC24BIT | DACFS48,
            WR | DACCTRL2 ,//| DACMUTE_R4 | DACMUTE_L4,
            WR | DACVOL_L1 | DACVOL_MAX,
            WR | DACVOL_R1 | DACVOL_MAX,
            WR | DACVOL_L2 | DACVOL_MAX,
            WR | DACVOL_R2 | DACVOL_MAX,
            WR | DACVOL_L3 | DACVOL_MAX,
            WR | DACVOL_R3 | DACVOL_MAX,
            WR | DACVOL_L4 | DACVOL_MAX,
            WR | DACVOL_R4 | DACVOL_MAX,
            WR | ADCCTRL1 | ADCFS48,
            WR | ADCCTRL2 | ADCI2S | ADC24BIT,
            WR | ADCCTRL3 | IMCLKx2
volatile int spiFlag ;
//Set up the SPI port to access the AD1835
void SetupSPI1835 ()
    /* First configure the SPI Control registers */
    /* First clear a few registers     */
    *pSPICTL = (TXFLSH | RXFLSH) ;
    *pSPIFLG = 0;
    /* Setup the baud rate to 1MHz */
    *pSPIBAUD = 100;
    /* Setup the SPI Flag register to FLAG3 : 0xF708*/
    *pSPIFLG = 0xF708;
    /* Now setup the SPI Control register : 0x5281*/
    *pSPICTL = (SPIEN | SPIMS | MSBF | WL16 | TIMOD1) ;
//Disable the SPI Port
void DisableSPI1835 ()
    *pSPICTL = (TXFLSH | RXFLSH);
//Send a word to the AD1835 via SPI
void Configure1835Register (int val)
    *pTXSPI = val ;
    Delay(100);
    //Wait for the SPI to indicate that it has finished.
    while (1)
        if (*pSPISTAT & SPIF)
            break ;
    Delay (100) ;
//Receive a register setting from the AD1835
unsigned int Get1835Register (int val)
    *pTXSPI = val ;
    Delay(100);
    //Wait for the SPI port to indicate that it has finished
    while (1)
        if (SPIF & *pSPISTAT)
            break ;
    Delay (100) ;
    return *pRXSPI ;
//  return i ;
//Set up all AD1835 registers via SPI
void Init1835viaSPI()
    int i ;
    SetupSPI1835 () ;
    for (i = 0; i < configSize; ++i)
        Configure1835Register (Config1835Param[i]) ;
    DisableSPI1835 () ;
//Delay loop
void Delay (int i)
    for (;i>0;--i)
        asm ("nop;") ;
