BF533 EZ KIT using DAC3
Question asked by ridwanoz on Sep 6, 2012
Latest reply on Oct 19, 2012 by Prashant
I work on ADSP BF533 EZ Kit Lite and i need to use DAC3 audio output also.
in order to achieve this i made some modifications on talkthrough example, which i copied it from installation directory.
However the following changes does not provide me to use DAC3 stereo output.
Red lines are the changes i made.
How can I use DAC3 stereo output ?
Thanks ,
Waiting for help,
Rıdvan
________________________________________
changes in Talkthrough.h file:
// names for slots in ad1836 audio frame
#define INTERNAL_ADC_L0                              0
#define INTERNAL_ADC_R0                              2
#define INTERNAL_DAC_L0                              0
#define INTERNAL_DAC_R0                              2
#define INTERNAL_ADC_L1                              1
#define INTERNAL_ADC_R1                              3
#define INTERNAL_DAC_L1                              1
#define INTERNAL_DAC_R1                              3
#define INTERNAL_DAC_L2                              4
#define INTERNAL_DAC_R2                              5
// Global variables        //
extern int iChannel0LeftIn;
extern int iChannel0RightIn;
extern int iChannel0LeftOut;
extern int iChannel0RightOut;
extern int iChannel1LeftIn;
extern int iChannel1RightIn;
extern int iChannel1LeftOut;
extern int iChannel1RightOut;
extern int iChannel2LeftOut;
extern int iChannel2RightOut;
extern volatile short sCodec1836TxRegs[];
extern volatile int iRxBuffer1[];
extern volatile int iTxBuffer1[];
changes in Process_data.c file:
iChannel0LeftOut = -iChannel1LeftIn;
iChannel0RightOut = iChannel1RightIn;
iChannel1LeftOut = -iChannel1LeftIn;
iChannel1RightOut = iChannel1RightIn;
iChannel2LeftOut = -iChannel1LeftIn;
iChannel2RightOut = iChannel1RightIn;
changes in ISR.c file:
  // copy processed data from variables into dma output buffer
  iTxBuffer1[INTERNAL_DAC_L0] = iChannel0LeftOut;
  iTxBuffer1[INTERNAL_DAC_R0] = iChannel0RightOut;
  iTxBuffer1[INTERNAL_DAC_L1] = iChannel1LeftOut;
  iTxBuffer1[INTERNAL_DAC_R1] = iChannel1RightOut;
  iTxBuffer1[INTERNAL_DAC_L2] = iChannel2LeftOut;
  iTxBuffer1[INTERNAL_DAC_R2] = iChannel2RightOut;
changes in main.c file:
// left input data from ad1836
int iChannel0LeftIn, iChannel1LeftIn;
// right input data from ad1836
int iChannel0RightIn, iChannel1RightIn;
// left ouput data for ad1836
int iChannel0LeftOut, iChannel1LeftOut;
// right ouput data for ad1836
int iChannel0RightOut, iChannel1RightOut;
int iChannel2LeftOut, iChannel2RightOut;
// array for registers to configure the ad1836
// names are defined in "Talkthrough.h"
volatile short sCodec1836TxRegs[CODEC_1836_REGS_LENGTH] =
                                                  DAC_CONTROL_1          | 0x000,
                                                  DAC_CONTROL_2          | 0x000,
                                                  DAC_VOLUME_0          | 0x3ff,
                                                  DAC_VOLUME_1          | 0x3ff,
                                                  DAC_VOLUME_2          | 0x3ff,
                                                  DAC_VOLUME_3          | 0x3ff,
                                                  DAC_VOLUME_4          | 0x3ff,
                                                  DAC_VOLUME_5          | 0x3ff,
                                                  ADC_CONTROL_1          | 0x000,
                                                  ADC_CONTROL_2          | 0x000,
                                                  ADC_CONTROL_3          | 0x000
// SPORT0 DMA transmit buffer
volatile int iTxBuffer1[6];
