Interfacing AD7495 through IIO Framework
Question asked by shekharlav on Aug 19, 2012
Latest reply on Aug 19, 2012 by Aaronwu
I am using a ADSP BF527 based board. I am using 2011R1 HEAD distro, with 2011R1-RC4 toolchain.
I am trying to interface AD7495 with my board through the IIO Framework.
I have followed the instructions given in http://wiki.analog.com/resources/tools-software/linux-drivers/iio-adc/ad7476a
Both AD7495 and AD7476A use the same driver.
But, the above page only talks about interfacing AD7476A. I wanted to confirm the mechanism for interfacing AD7495.
I believe that the only the declaration of the SPI slave device needs to be changed in the following manner.
static struct spi_board_info board_spi_board_info[] __initdata = {
#if defined(CONFIG_AD7476) || \
     defined(CONFIG_AD7476_MODULE)
/* the modalias must be the same as spi device driver name */
.modalias = "ad7495", /* Name of spi_driver for this device */
.max_speed_hz = 1000000,     /* max spi clock (SCK) speed in HZ */
.bus_num = 0, /* Framework bus number */
.chip_select = 3, /* Framework chip select */
.platform_data = NULL,
.controller_data = &ad7476_chip_info, /* Blackfin only */
.mode = SPI_MODE_0,
#endif
Note that only '.modalias' and '.platform_data' have been changed from those given in http://wiki.analog.com/resources/tools-software/linux-drivers/iio-adc/ad7476a#declaring_spi_slave_devices;
'.platform_data' has been set to 'NULL' since unlike AD7476, AD7495 has an internal Vref.
Please confirm the above changes, and let us know if any other modifications/additions need to be made.
Shekhar
