ADV7619 and sync
Question asked by msauer on Jul 31, 2012
Latest reply on Aug 2, 2012 by msauer
we use the adv7619 in our scaler board as hdmi frontend. I init the device with these parameter:
Init ADV:
s 98 1b 01; Sample ALBS (Device Adresse)
s 9a fa 9c; EDID Map auf Bank 0x9c
s 9a fb 9e; HDMI Map auf Bank 0x9e
s 9a fd a0; CP Map auf Bank 0xa0
s 9a f8 a2; DPLL Map auf Bank 0xa2
s 9e c0 03
s 9a 01 06; PRIM_MODE = 0110 HDMI-GR
s 9a 03 41; 30-Bit 4:4:4 SDR
s 9a 04 62; RGB Output, 28MHz
s 9a 05 28; AV Codes off
s 9a 0c 42; Power Up
s 9a 15 80; disable tristate
s 9a 19 83; LLC DLL phase
s 9a 33 40; LLC DLL Mux enable
s a0 ba 01; HDMI FreeRun
s a2 b5 01; MCLK to 256fs
s 9e 00 08; HDMI Port A, BG Meas Port B
s 9e 02 03; all BG ports enable
s 9e 3e 69
s 9e 3f 46
s 9e 4e 7e
s 9e 4f 42
s 9e 57 a3
s 9e 58 07
s 9e 83 fc; Enable termination
s 9e 84 03
s 9e 85 10
s 9e 86 9b
s 9e 89 03
s 9e 9b 03
The input is a HDMI/DVI signal with 1920x1080p 60Hz and 148MHz clock. The measurement registers are all correct but I can only measure a vsync frequenc of 16Hz and on hsync and de nothing. Do you have a hint to solve this problem.
Thank you for your help
best regards
martin sauer
