Alsa driver for TI codec with BF526 processor
Question asked by rrunmai on Jul 30, 2012
Latest reply on Aug 3, 2012 by ScottJiang
We have the TI codec TLV320AIC3254 connected to BF526 processor on I2C and SPORT0.  We used userspace I2C and Bfin-sport and could configure the codec and receive data from codec. As a next step we are trying to implement live recording.  We are trying to implement Alsa.  I got the linux driver code (tlv320aic32x4.c,tlv320aic32x4.h) form internet and have done the DAI platform - bf5xx_tlv320aic32x4.c similar to bf5xx_ssm2602.c.  I followed the steps given in http://wiki.analog.com/resources/tools-software/linux-drivers/sound/ssm2602.
But I could not found any sound cards here.  I try installing the Alsa as a module. But I could not find any snd-pcm-oss modules to be installed.
The log when it is built in kernel is attached.
This is my log file:
Jan  1 00:00:05 blackfin syslog.info syslogd started: BusyBox v1.16.2
Jan  1 00:00:05 blackfin user.notice kernel: klogd started: BusyBox v1.16.2 (2012-07-27 14:16:17 IST)
Jan  1 00:00:05 blackfin user.notice kernel: Linux version 3.1.0-rc1 (unmai@unmai-laptop) (gcc version 4.3.5 (ADI/svn-4960) ) #1512 Mon Jul 30 14:15:58 IST 2012
Jan  1 00:00:05 blackfin user.info kernel: register early platform devices
Jan  1 00:00:05 blackfin user.info kernel: bootconsole [early_shadow0] enabled
Jan  1 00:00:05 blackfin user.info kernel: bootconsole [early_BFuart0] enabled
Jan  1 00:00:05 blackfin user.info kernel: early printk enabled on early_BFuart0
Jan  1 00:00:05 blackfin user.info kernel: Board Memory: 32MB
Jan  1 00:00:05 blackfin user.info kernel: Kernel Managed Memory: 32MB
Jan  1 00:00:05 blackfin user.info kernel: Memory map:
Jan  1 00:00:05 blackfin user.info kernel:   fixedcode = 0x00000400-0x00000490
Jan  1 00:00:05 blackfin user.info kernel:   text      = 0x00001000-0x00186428
Jan  1 00:00:05 blackfin user.info kernel:   rodata    = 0x00186428-0x00202f1c
Jan  1 00:00:05 blackfin user.info kernel:   bss       = 0x00203000-0x002150ac
Jan  1 00:00:05 blackfin user.info kernel:   data      = 0x002150ac-0x00230000
Jan  1 00:00:05 blackfin user.info kernel:     stack   = 0x0022e000-0x00230000
Jan  1 00:00:05 blackfin user.info kernel:   init      = 0x00230000-0x0075d000
Jan  1 00:00:05 blackfin user.info kernel:   available = 0x0075d000-0x01f00000
Jan  1 00:00:05 blackfin user.info kernel:   DMA Zone  = 0x01f00000-0x02000000
Jan  1 00:00:05 blackfin user.info kernel: Hardware Trace active and enabled
Jan  1 00:00:05 blackfin user.info kernel: Boot Mode: 3
Jan  1 00:00:05 blackfin user.notice kernel: Reset caused by Software reset
Jan  1 00:00:05 blackfin user.debug kernel: free_area_init_node: node 0, pgdat 0022ba6c, node_mem_map 0075f000
Jan  1 00:00:05 blackfin user.debug kernel:   DMA zone: 62 pages used for memmap
Jan  1 00:00:05 blackfin user.debug kernel:   DMA zone: 0 pages reserved
Jan  1 00:00:05 blackfin user.debug kernel:   DMA zone: 7874 pages, LIFO batch:0
Jan  1 00:00:05 blackfin user.info kernel: NOMPU: setting up cplb tables
Jan  1 00:00:05 blackfin user.info kernel: Instruction Cache Enabled for CPU0
Jan  1 00:00:05 blackfin user.info kernel:   External memory: cacheable in instruction cache
Jan  1 00:00:05 blackfin user.info kernel: Data Cache Enabled for CPU0
Jan  1 00:00:05 blackfin user.info kernel:   External memory: cacheable (write-back) in data cache
Jan  1 00:00:05 blackfin user.debug kernel: pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
Jan  1 00:00:05 blackfin user.debug kernel: pcpu-alloc: [0] 0
Jan  1 00:00:05 blackfin user.warn kernel: Built 1 zonelists in Zone order, mobility grouping off.  Total pages: 7874
Jan  1 00:00:05 blackfin user.notice kernel: Kernel command line: root=/dev/mtdblock0 rw clkin_hz=25000000 earlyprintk=serial,uart0,57600 console=ttyBF0,57600 ip=10.7.143.88:10.7.143.13:10.7.143.22:255.255.255.0:bf526-tmbrd:eth0:off
Jan  1 00:00:05 blackfin user.info kernel: PID hash table entries: 128 (order: -3, 512 bytes)
Jan  1 00:00:05 blackfin user.info kernel: Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Jan  1 00:00:05 blackfin user.info kernel: Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Jan  1 00:00:05 blackfin user.info kernel: Calibrating delay loop... 595.96 BogoMIPS (lpj=1191936)
Jan  1 00:00:05 blackfin user.info kernel: pid_max: default: 32768 minimum: 301
Jan  1 00:00:05 blackfin user.info kernel: Security Framework initialized
Jan  1 00:00:05 blackfin user.info kernel: Mount-cache hash table entries: 512
Jan  1 00:00:05 blackfin user.info kernel: Blackfin Scratchpad data SRAM: 4 KB
Jan  1 00:00:05 blackfin user.info kernel: Blackfin L1 Data A SRAM: 16 KB (16 KB free)
Jan  1 00:00:05 blackfin user.info kernel: Blackfin L1 Data B SRAM: 16 KB (16 KB free)
Jan  1 00:00:05 blackfin user.info kernel: Blackfin L1 Instruction SRAM: 48 KB (42 KB free)
Jan  1 00:00:05 blackfin user.info kernel: NET: Registered protocol family 16
Jan  1 00:00:05 blackfin user.info kernel: Blackfin DMA Controller
Jan  1 00:00:05 blackfin user.info kernel: ezbrd_init(): registering device resources
Jan  1 00:00:05 blackfin user.info kernel: i2c register board info
Jan  1 00:00:05 blackfin user.info kernel: registering
Jan  1 00:00:05 blackfin user.info kernel: bio: create slab <bio-0> at 0
Jan  1 00:00:05 blackfin user.notice kernel: SCSI subsystem initialized
Jan  1 00:00:05 blackfin user.err kernel: bfin-spi bfin-spi.0: chipselect 1 already in use
Jan  1 00:00:05 blackfin user.err kernel: bfin-spi bfin-spi.0: can't create new device for spidev
Jan  1 00:00:05 blackfin user.info kernel: bfin-spi bfin-spi.0: Blackfin on-chip SPI Controller Driver, Version 1.0, regs@ffc00500, dma channel@7
Jan  1 00:00:05 blackfin user.info kernel: usbcore: registered new interface driver usbfs
Jan  1 00:00:05 blackfin user.info kernel: usbcore: registered new interface driver hub
Jan  1 00:00:05 blackfin user.info kernel: usbcore: registered new device driver usb
Jan  1 00:00:05 blackfin user.info kernel: i2c-bfin-twi i2c-bfin-twi.0: Blackfin BF5xx on-chip I2C TWI Contoller, regs_base@ffc01400
Jan  1 00:00:05 blackfin user.info kernel: Advanced Linux Sound Architecture Driver Version 1.0.24.
Jan  1 00:00:05 blackfin user.info kernel: NET: Registered protocol family 2
Jan  1 00:00:05 blackfin user.info kernel: IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Jan  1 00:00:05 blackfin user.info kernel: TCP established hash table entries: 1024 (order: 1, 8192 bytes)
Jan  1 00:00:05 blackfin user.info kernel: debug-mmrs: setting up Blackfin MMR debugfs
Jan  1 00:00:05 blackfin user.info kernel: JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
Jan  1 00:00:05 blackfin user.info kernel: msgmni has been set to 46
Jan  1 00:00:05 blackfin user.info kernel: io scheduler noop registered (default)
Jan  1 00:00:05 blackfin user.info kernel: bfin-uart: Blackfin serial driver
Jan  1 00:00:05 blackfin user.info kernel: bfin-uart.0: ttyBF0 at MMIO 0xffc00400 (irq = 29) is a BFIN-UART
Jan  1 00:00:05 blackfin user.info kernel: bfin-uart.1: ttyBF1 at MMIO 0xffc02000 (irq = 31) is a BFIN-UART
Jan  1 00:00:05 blackfin user.info kernel: brd: module loaded
Jan  1 00:00:05 blackfin user.notice kernel: physmap platform flash device: 00400000 at 20000000
Jan  1 00:00:05 blackfin user.err kernel: physmap-flash physmap-flash.0: map_probe failed
Jan  1 00:00:05 blackfin user.warn kernel: m25p80 spi0.1: found w25q128, expected sst25wf040
Jan  1 00:00:05 blackfin user.info kernel: m25p80 spi0.1: w25q128 (16384 Kbytes)
Jan  1 00:00:05 blackfin user.notice kernel: Creating 5 MTD partitions on "m25p80":
Jan  1 00:00:05 blackfin user.notice kernel: 0x000000000000-0x000000040000 : "bootloader"
Jan  1 00:00:05 blackfin user.notice kernel: 0x000000040000-0x0000001c0000 : "linux kernel"
Jan  1 00:00:05 blackfin user.info kernel: usbcore: registered new interface driver usb-storage
Jan  1 00:00:05 blackfin user.info kernel: USB Mass Storage support registered.
Jan  1 00:00:05 blackfin user.info kernel: bfin-wdt: initialized: timeout=20 sec (nowayout=0)
Jan  1 00:00:05 blackfin user.warn kernel: PG12 reserved for ADC chip select
Jan  1 00:00:05 blackfin user.warn kernel: Going to read ID
Jan  1 00:00:05 blackfin user.warn kernel: read returned 0
Jan  1 00:00:05 blackfin user.warn kernel: Got ID ff
Jan  1 00:00:05 blackfin user.err kernel: ad7793 spi0.2: device ID query failed
Jan  1 00:00:05 blackfin user.err kernel: ad7793 spi0.2: setup failed
Jan  1 00:00:05 blackfin user.info kernel: bfin-i2s bfin-i2s.0: dma rx:3 tx:4, err irq:15, regs:ffc00800
Jan  1 00:00:05 blackfin user.info kernel: ALSA device list:
Jan  1 00:00:05 blackfin user.info kernel:   No soundcards found.
Jan  1 00:00:05 blackfin user.info kernel: TCP cubic registered
Jan  1 00:00:05 blackfin user.info kernel: NET: Registered protocol family 17
Jan  1 00:00:05 blackfin user.info kernel: dma_alloc_init: dma_page @ 0x017da000 - 256 pages at 0x01f00000
Jan  1 00:00:05 blackfin user.warn kernel: IP-Config: Complete:
Jan  1 00:00:05 blackfin user.warn kernel:      device=eth0, addr=10.7.143.88, mask=255.255.255.0, gw=10.7.143.22,
Jan  1 00:00:05 blackfin user.warn kernel:      host=bf526-tmbrd, domain=, nis-domain=(none),
Jan  1 00:00:05 blackfin user.warn kernel:      bootserver=10.7.143.13, rootserver=10.7.143.13, rootpath=
Jan  1 00:00:05 blackfin user.info kernel: Freeing unused kernel memory: 5300k freed
Jan  1 00:00:05 blackfin user.info kernel: PHY: 0:10 - Link is Up - 100/Full
Jan  1 00:03:24 blackfin auth.info rshd[84]: unmai@10.7.143.19 as root: cmd='rcp -f /var/log/messages'
