How to wire eval-ad76xxedz to DSP
Question asked by Sumit on Jul 25, 2012
Latest reply on Jul 31, 2012 by clairec
I have an eval board for AD7610 (eval - AD76xx - Rev J) and want to integrate it to a DSP via SPI.
DSP: SPI Master
AD7610 Eval Board: SPI Slave
See picture below.
After reading thru the document (EVAL-AD76xxEDZ) several times.
Here are my jumper settings on the eval board
JP1,JP2: BUFF
JP3: -12V
JP4: REF
JP6: 3.3V
JP7: +12V
JP8: +12V
JP9: VDIG
JP19: AVDD
JP20: BUF
JP21: 3.3V
JP22: \CNVST: External
Here are S16 Select Switch
  1. Warp: Low
  2. Impulse: Low
  3. Bip: Low
  4. Ten: Low
  5. A0/M0: Low
  6. Byte/M1: Low
  7. OB/2C: Low
  8. Ser/Par: High
  9. Ext/Int: High
  10. InvSync: Low
  11. InvSClk: Low
  12. RDC: Low
S35 Select Switch
  1. Reset: Low
  2. PD: Low
  3. PDBUF: Low
  4. PDREF: Low
Since DSP will run in master SPI mode, it will provide the serial clock. So where do I wire the DSPs SPI Clock for AD7610 Conversion?
In stand alone mode, the gate arrays flexible logic buffers the ADC data and provides the serial clock source (40MHz).
So how do I bypass the gate array (Or do I)?
Is it possible to interface a DSP to AD7610 eval board via SPI?
Thank You,
Sumit
