read(), termios VMIN,VTIME no effect
Question asked by feucom on Jul 23, 2012
Latest reply on Jul 27, 2012 by feucom
read() seams to ignore termios settings VMIN/VTIME. I try to adjust the timeout with VMIN and VTIME, but it has no effect, even VMIN=0,VTIME=0. If no bytes no bytes arrive I would expect that read() returns at least NULL but it returns nothing and stays for infinity in waiting loop. Could you tell me what wrong in my settings, please?
Thanks
Ralph
HW : stamp board BF537
int open_port(char *tty_port)
    int fd; // file description for the serial port
    char path[20] = "/dev/";
    strcat(path, tty_port);
    fd = open(path, O_RDWR | O_NOCTTY | O_NDELAY);
    if(fd < 0) // if open is unsucessful
        perror("open_port: Unable to open /dev/ttyBF1 - ");
        printf("open_port: Unable to open /dev/,%s \n",tty_port);
    else
        fcntl(fd, F_SETFL, 0);                //normal blocking behavior (already done by O_NDELAY)
        printf("port, %d, is open.\n", fd);
    return(fd);
int configure_port(int fd)      // configure the port
    struct termios tty_config;
    if (tcgetattr(fd, &tty_config)<0) printf( "failed to get initial config\n" );
          tty_config.c_cflag &= ~PARENB;    //parity enable
          tty_config.c_cflag &= ~CSTOPB;    //2 stopbit otherwise one
          tty_config.c_cflag &= ~CSIZE;        //bitmask for data bit
          tty_config.c_cflag &= ~CRTSCTS;    //hardware fc
          tty_config.c_cflag |= CS8;        //8 bit
          tty_config.c_cflag |= CREAD;        // rx enable
          tty_config.c_cflag |= CLOCAL;        //local line
//      tty_config.c_cflag |= HUPCL;        //hang upon last close
          tty_config.c_lflag &= ~ICANON;    //canonical
          tty_config.c_lflag &= ~ECHOCTL;    //echo NL
          tty_config.c_lflag &= ~ECHOKE;    //BS-SP-BS entier line lin kill
          tty_config.c_lflag &= ~ECHOK;        //echo NL after NL kill
          tty_config.c_lflag &= ~ECHO;        //echo
          tty_config.c_lflag &= ~ECHOE;        //echo erase char
          tty_config.c_lflag &= ~ISIG;        //signature
          tty_config.c_lflag &= ~IEXTEN;    //enable ext. function
          tty_config.c_iflag &= ~IXON;        //outgoing soft FC
          tty_config.c_iflag &= ~IXOFF;        //incoming soft FC
          tty_config.c_iflag &= ~IXANY;        //allow any char to star flowcontrol
          tty_config.c_iflag &= ~ICRNL;        //map CR to NL
          tty_config.c_iflag &= ~INLCR;        //map NL to CR
          tty_config.c_iflag |=  IGNCR;        //ignore CG
          tty_config.c_oflag &= ~OPOST;        //postprocess output
          tty_config.c_oflag &= ~ONLCR;        //map NL to CR-NL
          tty_config.c_cc[VMIN]  = 2;                    //min number of bytes to read
          tty_config.c_cc[VTIME] = 50;                    //timeout 10 *1/10 = 1 sec
//              set ttyflags "-icrnl -ixon igncr -opost -onlcr -isig -icanon -iexten -echo -echoe -echok
//           *                -echoke -hupcl -echoctl -parenb -parodd cs8 hupcl -cstopb cread clocal -crtscts min 1 time 0"
    if (cfsetispeed(&tty_config, B9600)<0) printf( "failed to set in put baud rate\n" );
    if (cfsetospeed(&tty_config, B9600)<0) printf( "failed to set output baud rate\n" );
    if (tcsetattr(fd, TCSANOW, &tty_config)<0)printf( "failed to apply config\n" );
    return(fd);
