如何减小mtd_size ?
Question asked by jizhenyue on Jul 18, 2012
Latest reply on Jul 19, 2012 by Aaronwu
开发板为BF512,内存32MB。 移植uclinux系统至开发板后,rootfs无法映射到内存。初步认为是内存太小所导致,请问应该如何减小mtd_size? 或者应该如何修改文件系统到内存的映射?望不吝赐教!谢谢!
以下为开发板上电后的打印信息:
NAND read: device 0 offset 0x0, size 0x200000
2097152 bytes read: OK
## Booting kernel from Legacy Image at 01000000 ...
   Image Name:   bf512-0.1-3.0.8-ADI-2011R1-svn52
   Created:      2012-07-17   8:47:40 UTC
   Image Type:   Blackfin Linux Kernel Image (gzip compressed)
   Data Size:    1159747 Bytes = 1.1 MiB
   Load Address: 00001000
   Entry Point:  001ebc4c
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
Starting Kernel at = 001ebc4c
Linux version 3.0.8-ADI-2011R1-svn52 (gcc version 4.3.5 (ADI-201
2R1-BETA1) ) #2 Tue Jul 17 04:46:40 EDT 2012
register early platform devices
Could not find valid ram mtd attached.
Board Memory: 32MB
Kernel Managed Memory: 32MB
Memory map:
  fixedcode = 0x00000400-0x00000490
  text      = 0x00001000-0x0015c618
  rodata    = 0x0015c618-0x001c2db8
  bss       = 0x001c3000-0x001d34e8
  data      = 0x001d34e8-0x001e8000
    stack   = 0x001e6000-0x001e8000
  init      = 0x001e8000-0x00203000
  available = 0x00203000-0x01f00000
  rootfs    = 0x  (null)-0x  (null)
  DMA Zone  = 0x01f00000-0x02000000
Hardware Trace active and enabled
Boot Mode: 3
Blackfin support (C) 2004-2010 Analog Devices, Inc.
Compiled for ADSP-BF512 Rev 0.1
Blackfin Linux support by http://blackfin.uclinux.org/
Processor Speed: 300 MHz core clock and 75 MHz System Clock
Instruction Cache Disabled for CPU0
Data Cache Disabled for CPU0
Built 1 zonelists in Zone order, mobility grouping off.  Total pages: 7874
Kernel command line: root=/dev/mtdblock2 rw rootfstype=jffs2 clkin_hz=25000000 e
arlyprintk=serial,uart0,115200 console=ttyBF0,115200
PID hash table entries: 128 (order: -3, 512 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory available: 29356k/32768k RAM, (108k init code, 1389k kernel code, 559k da
ta, 1024k dma, 332k reserved)
NR_IRQS:159
Configuring Blackfin Priority Driven Interrupts
bfin-rtc: invalid date; resetting
console [ttyBF0] enabled
Calibrating delay loop... 571.39 BogoMIPS (lpj=1142784)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
Blackfin Scratchpad data SRAM: 4 KB
Blackfin L1 Data A SRAM: 32 KB (31 KB free)
Blackfin L1 Data B SRAM: 32 KB (32 KB free)
Blackfin L1 Instruction SRAM: 32 KB (20 KB free)
NET: Registered protocol family 16
Blackfin DMA Controller
dso0324_init(): registering device resources
bio: create slab <bio-0> at 0
SCSI subsystem initialized
Switching to clocksource bfin_cs_cycles
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
msgmni has been set to 57
Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
io scheduler noop registered
io scheduler cfq registered (default)
bfin-uart: Blackfin serial driver
bfin-uart.0: ttyBF0 at MMIO 0xffc00400 (irq = 29) is a BFIN-UART
bfin-uart.1: ttyBF1 at MMIO 0xffc02000 (irq = 31) is a BFIN-UART
bfin-sport-uart: Blackfin uart over sport driver
bfin-sport-uart.0: ttySS0 at MMIO 0xffc00800 (irq = 23) is a BFIN-SPORT-UART
bfin-sport-uart.1: ttySS1 at MMIO 0xffc00900 (irq = 25) is a BFIN-SPORT-UART
brd: module loaded
uclinux[mtd]: RAM probe address=0x1c30e8 size=0xa3f000
Creating 1 MTD partitions on "RAM":
0x000000000000-0x000000a3f000 : "ROMfs"
Generic platform RAM MTD, (c) 2004 Simtec Electronics
NAND device: Manufacturer ID: 0xec, Chip ID: 0xda (Samsung NAND 256MiB 3,3V 8-bi
t)
Scanning device for bad blocks
Bad eraseblock 35 at 0x000000460000
Bad eraseblock 44 at 0x000000580000
Bad eraseblock 45 at 0x0000005a0000
Bad eraseblock 46 at 0x0000005c0000
Bad eraseblock 47 at 0x0000005e0000
Bad eraseblock 48 at 0x000000600000
Bad eraseblock 49 at 0x000000620000
Bad eraseblock 50 at 0x000000640000
Bad eraseblock 51 at 0x000000660000
Bad eraseblock 994 at 0x000007c40000
Creating 2 MTD partitions on "gen_nand":
0x000000000000-0x000000400000 : "linux kernel(nand)"
0x000000400000-0x000010000000 : "file system(nand)"
dm9000 Ethernet Driver, V1.31
dm9000 dm9000.0: eth%d: Invalid ethernet MAC address. Please set using ifconfig
eth0: dm9000a at 20000000,20000002 IRQ 88 MAC: ca:52:de:25:8f:2c (random)
