AD7747 CDC Setting Registers
Question asked by kimimaro on Jul 17, 2012
Latest reply on Jul 20, 2012 by kimimaro
I am trying to make a continious single channel capacitance reader circuit. I am using PIC16F877 as host microcontroller and AD7747 capacitance to digital converter. I am having troubles with setting the registers. I can not set the resgisters as I want, or they are changed on their own.
Register NameRegister AddressDefault ValueAfter Reset ValueSet ValueAfter Setting Value
Cap Setup Register0x070x000x000xA00xA0
VT Setup Register0x080x000x03 *0x830x83
EXC Setup Register0x090x030x030x0F0xA1 *
Configuration Register0x0A0xA00xA00xA10x03 *
CAP DAC A Register0x0B0x000x000x000x00
CAP DAC B Register0x0C0x000x000x000x7F *
16 bits Cap Offset
Calibration Register
0x0D
0X0E
0x80
0x00
0x80
0xF8 *
0x80
0x00
0x80
0xF8 *
The register values with stars indicates unexpected results.
Here is the procedure of above table.
1- Reset
2- Read registers
3- wait 1 second
4- Set registers
5- Read registers
And the C code for reading registers from I2C. I read from I2C register values and store them at a byte array
          for(counter=0x00;counter<0x10;counter++){
          i2c_start();
          delay_us(20);
          i2c_write(0x90);
          delay_us(20);
          i2c_write(counter);
          delay_ms(10);
          i2c_start();
          delay_us(20);
          i2c_write(0x91);
          delay_us(20);
          register_values[counter] = i2c_read();
And C code for setting a register (configuration register as an example);
void configuration_register(){
     i2c_start();
     delay_us(20);
     i2c_write(0x90);
     delay_us(20);
     i2c_write(0x0A);
     delay_us(20);
     i2c_write(0xA1);
     delay_us(20);
