how to configure 7441a for the DVI input?
Question asked by greatmike@hotmail.com on Jul 3, 2012
Latest reply on Jul 7, 2012 by greatmike@hotmail.com
hi, buddy
     I have a problem. My system consist of a 7441a and a 9889b  and the input is DVI signal which goes through 7441a and 9889b then output DVI signal. But on the display the image is not clear, and has some beating lines and the color is fuzzy.
     I use script  ADV7441A_ADV7441A@_ADV7441AVDP_ADV7441AHDMI_ADV7341-VER.MB2.0.TXT, as below:
##HDMI PORTA out through DAC/HDMI ##
:Port A  RGB/YPrPb 444 25Mhz <  f < 160MHz 30Bit IN RGB 444 OUT through DAC/HDMI Audio through Tx FS = 48KHz:
42 03 0C ; Disable TOD
42 05 06 ; Prim_Mode =0110b HDMI
42 1D 40 ; Disable TRI_LLC
42 37 00 ; Disable PCLK
42 6B E2 ; Setting cp_op_sel = 2 & Enable DE
42 68 F2 ; Auto CSC , RGB Out
42 BA A0 ; Enable HDMI and Analog in
42 C8 08 ; Digital Fine Clamp Start position
42 7B 0D ; Disable AV code Insertion
42 F4 3F ; Max Drive Strength
62 F0 10 ; ADI Recommended Write
62 F1 0F ; ADI Recommended Write
62 F4 20 ; ADI Recommended Write
6A 15 EC ; Disable these mute mask bits
6A 1C 58 ; Set MCLKOUT to output 128fs
6A 1D 04 ;  & Set Unmute Delay to 1_5 sec.
6A 3C 42 ; Set MCLKOUT to output 128fs
6A 3D 40 ; Change the VCO range for the audio PLL
6A 5A 01 ; Reset Audio Pll
/////50 22 01 ; HDMI Powerup 01
//////50 20 17 ; HPD
//////50 20 07 ; HPD
//////50 10 07 ; Mux Signals to Tx and DAC
7A 41 10 ; Power Up
7A A1 7C ; Power down TMDS lines
7A AF 16 ; Tx in HDMI Mode
7A 01 00 ; Set ACR 'N' value at 6144 (48KHz)
7A 02 18 ; Set ACR 'N' value at 6144 (48KHz)
7A 03 00 ; Set ACR 'N' value at 6144 (48KHz)
7A 0A 0C ; External CTS.MCLK Ratio, SET FOR 128FS as is DECODER.
7A 15 20 ; 24-bit, 444 YPrPb input, 48kHz Fs
7A 50 20 ; 2 ch mode
7A 17 02 ; Aspect ratio 16to9
7A 44 F8 ; spdif_en
7A 96 C4 ; Mask interrupts
7A 98 03 ; RSVD but Must Write
7A 9C 38 ; RSVD but Must Write
7A 9D 61 ; RSVD but Must Write
7A A2 87 ; RSVD but Must Write
7A A3 87 ; RSVD but Must Write
7A A5 C0 ; RSVD but Must Write
7A AB 00 ; RSVD but Must Write
7A AF 16 ; HDMI Mode Enable
7A BA 60 ; Pos Edge Clk
7A A1 00 ; Power up TMDS lines
End
I think I should modify the above script, but how to modify? Could you help me?
Thank you very much.
