ADIS16360 DRIVER HELP
Question asked by ALCENGINEER on Jul 2, 2012
Latest reply on Jul 2, 2012 by NevadaMark
I was hoping that some one could help me with making a driver for the ADIS16360. I am currently getting data, but with a lot of drift. my current set up is as mentioned an adis16360 connected to a microchip 18F45K20 and my compiler is CCS. I am polling for data mostly from XACCL_OUT register and am getting (when not in motion). number between 1 and 5. I am polling at a rate of 5hz. because my numbers are all positive I am always drifting at a proximity 3 mm per cycle. I do have it set up correctly to get get negitve numbers. My code is as follows:
ACCL= spi_xfer(INS, ADDRESS, 16);        // get SPI INFO
UNREAD= ACCL & 0x8000;        // get rid of everything except for the MSB
ERROR=ACCL 7 0x4000;        // get rid of everything except for the 15th bit
IF( UNREAD == 0x8000 && ERROR != 0x4000){                                                     // if MSB =1 and 13th bit does not equal one then continue
     ACCL =ACCL & 3FFF;        // get rid of the last 2 bits
     IF(ACCL >= 0x2000){        // IF the 14th bit  is one
          ACCL= ACCL & 0x1FFF;        // get rid of the 14th bit
          ACCL = ACCL - 0x2000;}        // subtact 8192
FLACCL = ACCL * 3.333;        //* by units(mG per sec)
FLACCL = FLACCL * .980665;        // convert to mm per sec
ACCLP= ACCLP + (FLACCL * .2);        //add initail distance to current distance( acceleration times 5hz)
RETURN(ACCLP);
IF my math looks right then I thought that it could need to be calibrated.  this part confuses me. to do a precision atuonull command the data sheet states that I need to call the GLOB_CMD register. the register should be 0x3E. and in the example to flip bit [7] I should write 0xBE80??? I also should be able to write 0x3E00 to stat a burst read sequence???
thanks in advance for your thoughts
Andrew
