problem in booting uImage?
Question asked by rjustin24 on Jun 28, 2012
Latest reply on Jun 29, 2012 by rjustin24
After trying to load uImage. Im now stucked while uImage is being booted. What happens is that it gets stuck on a specific line. Anyone got an idea how to resolve this?
U-Boot 2011.09 (ADI-2011R1) (Dec 14 2011 - 13:56:11)
CPU:   ADSP bf537-0.2 (Detected Rev: 0.2) (bypass boot)
Board: ADI BF537 stamp board
       Support: http://blackfin.uclinux.org/
Clock: VCO: 500 MHz, Core: 500 MHz, System: 125 MHz
RAM:   64 MiB
Flash: 4 MiB
MMC:
In:    serial
Out:   serial
Err:   serial
KGDB:  [on serial] ready
Warning: Generating 'random' MAC address
Net:   bfin_mac
Hit any key to stop autoboot:  0
bfin_mac: link down, check cable
## Booting kernel from Legacy Image at 01000000 ...
   Image Name:   bf537-0.2-3.0.8-ADI-2011R1
   Created:      2012-06-29   4:17:07 UTC
   Image Type:   Blackfin Linux Kernel Image (gzip compressed)
   Data Size:    964878 Bytes = 942.3 KiB
   Load Address: 00100000
   Entry Point:  00297a40
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
Starting Kernel at = 00297a40
Linux version 3.0.8-ADI-2011R1 (root@ubuntu) (gcc version 4.5.3 (ADI-2
register early platform devices
bootconsole [early_shadow0] enabled
bootconsole [early_BFuart0] enabled
early printk enabled on early_BFuart0
Limiting kernel memory to 56MB due to anomaly 05000263
Board Memory: 64MB
Kernel Managed Memory: 64MB
Memory map:
  fixedcode = 0x00000400-0x00000490
  text      = 0x00100000-0x00217288
  rodata    = 0x00217288-0x0026ef30
  bss       = 0x0026f000-0x0027ea94
  data      = 0x0027eaa0-0x00290000
    stack   = 0x0028e000-0x00290000
  init      = 0x00290000-0x002aa000
  available = 0x002aa000-0x03800000
  DMA Zone  = 0x03e00000-0x04000000
Hardware Trace active and enabled
Boot Mode: 0
Blackfin support (C) 2004-2010 Analog Devices, Inc.
Compiled for ADSP-BF537 Rev 0.2
Blackfin Linux support by http://blackfin.uclinux.org/
Processor Speed: 500 MHz core clock and 125 MHz System Clock
NOMPU: setting up cplb tables
Instruction Cache Enabled for CPU0
  External memory: cacheable in instruction cache
Data Cache Enabled for CPU0
  External memory: cacheable (write-back) in data cache
Built 1 zonelists in Zone order, mobility grouping off.  Total pages:4
Kernel command line: root=/dev/mtdblock0 rw clkin_hz=25000000 earlyprf
PID hash table entries: 256 (order: -2, 1024 bytes)
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory available: 54008k/65536k RAM, (104k init code, 1116k kernel co)
NR_IRQS:146
Configuring Blackfin Priority Driven Interrupts
console [ttyBF0] enabled, bootconsole disabled
Calibrating delay loop... 995.32 BogoMIPS (lpj=1990656)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
Blackfin Scratchpad data SRAM: 4 KB
Blackfin L1 Data A SRAM: 16 KB (16 KB free)
Blackfin L1 Data B SRAM: 16 KB (16 KB free)
Blackfin L1 Instruction SRAM: 48 KB (47 KB free)
NET: Registered protocol family 16
Blackfin DMA Controller
stamp_init(): registering device resources
bio: create slab <bio-0> at 0
bfin-spi bfin-spi.0: Blackfin on-chip SPI Controller Driver, Version 7
Switching to clocksource bfin_cs_cycles
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
debug-mmrs: setting up Blackfin MMR debugfs
msgmni has been set to 105
io scheduler noop registered (default)
bfin-uart: Blackfin serial driver
bfin-uart.0: ttyBF0 at MMIO 0xffc00400 (irq = 18) is a BFIN-UART
bfin-uart.1: ttyBF1 at MMIO 0xffc02000 (irq = 20) is a BFIN-UART
brd: module loaded
bfin_mii_bus: probed
bfin_mac: attached PHY driver [SMSC LAN83C185] (mii_bus:phy_addr=0:01)
bfin_mac bfin_mac.0: eth0: Blackfin on-chip Ethernet MAC driver, Vers1
rtc-bfin rtc-bfin: rtc core: registered rtc-bfin as rtc0
TCP cubic registered
rtc-bfin rtc-bfin: setting system clock to 1970-01-01 00:01:09 UTC (6)
dma_alloc_init: dma_page @ 0x02122000 - 512 pages at 0x03e00000
IP-Config: Complete:
     device=eth0, addr=192.168.0.15, mask=255.255.255.0, gw=192.168.0,
     host=bf537-stamp, domain=, nis-domain=(none),
     bootserver=192.168.0.2, rootserver=192.168.0.2, rootpath=
List of all partitions:
No filesystem could mount root, tried:
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-b)
Hardware Trace:
   0 Target : <0x0021581c> { _dump_stack + 0x0 }
     Source : <0x002158a4> { _panic + 0x50 } CALL pcrel
   1 Target : <0x002158a4> { _panic + 0x50 }
     Source : <0x002159e0> { _printk + 0x14 } RTS
   2 Target : <0x002159dc> { _printk + 0x10 }
     Source : <0x001110fc> { _vprintk + 0x198 } RTS
   3 Target : <0x001110f0> { _vprintk + 0x18c }
     Source : <0x00109076> { __common_int_entry + 0xda } RTI
   4 Target : <0x00109014> { __common_int_entry + 0x78 }
     Source : <0x00108e50> { _return_from_int + 0x58 } RTS
   5 Target : <0x00108e50> { _return_from_int + 0x58 }
     Source : <0x00108e26> { _return_from_int + 0x2e } IF !CC JUMP pc
   6 Target : <0x00108df8> { _return_from_int + 0x0 }
     Source : <0x00109010> { __common_int_entry + 0x74 } JUMP.L
   7 Target : <0x0010900e> { __common_int_entry + 0x72 }
     Source : <0x00103662> { _asm_do_IRQ + 0x6a } RTS
   8 Target : <0x0010365a> { _asm_do_IRQ + 0x62 }
     Source : <0x0011498e> { ___local_bh_enable + 0x36 } RTS
   9 Target : <0x00114958> { ___local_bh_enable + 0x0 }
     Source : <0x00114ed2> { ___do_softirq + 0xae } CALL pcrel
  10 Target : <0x00114ec6> { ___do_softirq + 0xa2 }
     Source : <0x00114eba> { ___do_softirq + 0x96 } IF CC JUMP pcrel
  11 Target : <0x00114eae> { ___do_softirq + 0x8a }
     Source : <0x0013625e> { _rcu_bh_qs + 0x42 } RTS
  12 Target : <0x00136244> { _rcu_bh_qs + 0x28 }
     Source : <0x00136234> { _rcu_bh_qs + 0x18 } IF CC JUMP pcrel
  13 Target : <0x0013621c> { _rcu_bh_qs + 0x0 }
     Source : <0x00114eaa> { ___do_softirq + 0x86 } CALL pcrel
  14 Target : <0x00114ea2> { ___do_softirq + 0x7e }
     Source : <0x001188dc> { _run_timer_softirq + 0xb4 } RTS
  15 Target : <0x0011887e> { _run_timer_softirq + 0x56 }
     Source : <0x001188c8> { _run_timer_softirq + 0xa0 } IF !CC JUMP )
Stack info:
SP: [0x0201bf28] <0x0201bf28> /* kernel dynamic memory (maybe user-s/
FP: (0x0201bfe4)
Memory from 0x0201bf20 to 0201c000
0201bf20: 0201bf28  00000000 [0024292c] 002158a8  02061000  0024292c
0201bf40: 002743df  0201bf70  00000000  00290992  02061000  002a34bc
0201bf60: 00008000  00242994  00000000  002a347d  0201bf80  0201bf80
0201bf80: 6e6b6e75  2d6e776f  636f6c62  2c30286b  02002930  00290aa2
0201bfa0: 00290c1c  0026f068  002a34c8  00000000  00000000  00000000
0201bfc0: 00290688  0026f018  002a7fac  00000000  00290694  0026f018
0201bfe0: 00000000 (00000000)
00000000  00000000  00000000  ffffffff  00000006
Return addresses in stack:
   frame  1 : <0x00100616> { _kernel_thread_helper + 0x6 }
