SPI0 ISR Status Flag wrong - BF548
Question asked by Johan@Hannes on Jun 27, 2012
Hi @ all,
I run into an issue -a pretty strange behavoir- but let me summarize:
I try to start a simple interrupt driven SPI communication(RDBR - driven).Please find my code below.
I've written an interrupt routine and in my opinion I've initilized interrupt controller and registers properly.
Trying to read some byte(in SPI_CORE_READ( )) i tryied to initiate transfer by loading a command into TDBR Reg of SPI0 and afterwards making a dummy read. Now one could expect, that in SIC_ISR0 proper bit is set to signal interrupt and the program run into service routine. A Flag is set indeed, not for SPI0 status interrupt but for SPI0 DMA4 channel. Further i don't get to ISR at all. What I'm doing wrong?
Thanks for help in advance!
#define EBIU_DDRCTL0_DEF       (UINT32)(0x220A840DU)   /* PRQA S 303*/ /* AD definition, DDR CTL 0*/
#define EBIU_DDRCTL1_DEF       (UINT32)(0x10026222U)   /* PRQA S 303*/ /*AD definition,  DDR CTL 1*/
#define EBIU_DDRCTL2_DEF       (UINT32)(0x00000061U)   /* PRQA S 303*/ /* AD definition, DDR CTL 2*/
#define VRCTL                  (UINT16)(0x40DB)       /* PRQA S 303*/ /* AD definition, VRCTL*/
#define CORE_SPI_CONFIG_RD(MSTR|POLARITY_HI|CLKPHA_LO|RDBR_CORE)
VOID InitCommon()
   CPU_Init();
   SPI_INIT();
   (VOID)register_handler(ik_ivg7, (SPI0_TX_ISR));       //Register the SPI0 interrupt handler
   *pSIC_IAR0   &= ~(0x00200000);                        //Interrupt Assignement Reg. SPI0 Status
   ssync();
VOID CPU_Init (VOID)
  ADI_SYSCTRL_VALUES tSysCtrl;
  // program the PLL for a 400MHz Core CLK, and 100MHz SCLK
  //(based on CCLK = CLKIN*MSEL; SCLK = CCLK/SSEL; here: MSEL = 16, SSEL = 3 and CLKIN = 25MHz)
  tSysCtrl.uwPllCtl = PLL_MSEL_VALUE<<9;
  tSysCtrl.uwPllDiv = PLL_SSEL_VALUE;
  tSysCtrl.uwVrCtl  = VRCTL;
  //response will not be handled, since not necessary
  (void)bfrom_SysControl( SYSCTRL_WRITE | SYSCTRL_PLLCTL | SYSCTRL_PLLDIV  | SYSCTRL_VRCTL | SYSCTRL_INTVOLTAGE, &tSysCtrl, NULL);
    ssync();
  // configure the EBIU based on calculation from 'Firmware/Doc/BlackfinRegisterCalculations.xls'
  *pEBIU_DDRCTL0 = EBIU_DDRCTL0_DEF;                       /* PRQA S 303,1281*/ /* AD definition*/
  *pEBIU_DDRCTL1 = EBIU_DDRCTL1_DEF;                       /* PRQA S 303,1281*/ /* AD definition*/
  *pEBIU_DDRCTL2 = EBIU_DDRCTL2_DEF;                      /* PRQA S 303,1281*/ /* AD definition*/
  ssync();
}/*CPU_Init*/
VOID SPI_INIT()
   DISSpi0();
   *pPORTE_FER      |= PE0 | PE1 | PE2;                         //FER Reg.Port E
   *pPORTE_MUX      |= MUX0_0 | MUX1_0 | MUX2_0;        //MUX-->enable SPI channels
   *pPORTE_DIR_SET  |= (PE4);                                       //Config. CS for SPI0
   *pSPI0_BAUD       = BAUD_RATE_DIVISOR;                 //Set Baud rate
      ClearCS();        //Pull up CS
   ssync();
VOID SPI_CORE_READ(UINT32 u32Count, UINT32 u32Address)
   BYTE bDummyread = 0x00;                                                          /* PRQA S 3203*/ /* Variable needed to empty RDBR*/
   UINT16 u16I;
   u32ReadBufferCount=u32Count;                       //Bytes to read
    DISSpi0();        //Disable SPI0
    *pSIC_IMASK0 |= 0x00000020;                                  //Interrupt Mask Reg., Enable Interrupt SPIO Status
    ssync();
    *pSPI0_CTL    = CORE_SPI_CONFIG_RD;                 //Config. SPI0_CTL Reg.
   ssync();
   ENSpi0();                                          //Enable SPI0
   TriggerCS();                                       //Trigger CS
    *pSPI0_TDBR = CC2400_READ_COMMAND|u32Address;      /* Send read command + Address */
   bDummyread = (BYTE)*pSPI0_RDBR;                                   /* Dummy read to empty RDBR and trigger read operation */
EX_INTERRUPT_HANDLER(SPI0_TX_ISR)
   *pSPI0_TDBR = u16Dummy;                               //Dummy write
   aui8BufferR[u32BytesRead]=*pSPI0_RDBR;         //Read receive buffer
   ssync();
