kernel build issues
Question asked by dlh on Jun 26, 2012
Latest reply on Jun 27, 2012 by Aaronwu
I am having some issues trying to compile the kernel.. I have tried several different sources and approaches, but each with their own issues. My target for now is the BF533 ezkit and I am currently just trying to build with defaults and then make customizations once this is working.
I am using the toolchain from the apt repository (after having issues building them from source) and they are on the path.
Any help would be appreciated.
From GIT sources, they are compiling against the GIT kernel which I have symbolically linked to with linux-2.6.x:
# configuration written to .config
make[2]: Leaving directory `/home/dan/git/uclinux-dist/config'
make[1]: Leaving directory `/home/dan/git/uclinux-dist'
dan@laptop:~/git/uclinux-dist$ make
/home/dan/git/uclinux-dist/vendors/config/bfin/config.arch:117:
/home/dan/git/uclinux-dist/vendors/config/bfin/config.arch:118: The Blackfin Silicon Revision you are targetting is not known.
/home/dan/git/uclinux-dist/vendors/config/bfin/config.arch:119: Please file a bug report about this.
/home/dan/git/uclinux-dist/vendors/config/bfin/config.arch:120:
/home/dan/git/uclinux-dist/vendors/config/bfin/config.arch:125:
/home/dan/git/uclinux-dist/vendors/config/bfin/config.arch:126: The Blackfin CPU you are targetting is not known.
/home/dan/git/uclinux-dist/vendors/config/bfin/config.arch:127: Please file a bug report about this.
/home/dan/git/uclinux-dist/vendors/config/bfin/config.arch:128:
make -C tools/sg-cksum
make[1]: Entering directory `/home/dan/git/uclinux-dist/tools/sg-cksum'
make[1]: `cksum' is up to date.
make[1]: Leaving directory `/home/dan/git/uclinux-dist/tools/sg-cksum'
ln -sf /home/dan/git/uclinux-dist/tools/sg-cksum/cksum tools/cksum
make -f tools/autotools.mk autotools-cache
make[1]: Entering directory `/home/dan/git/uclinux-dist'
set -e; \
        mkdir -p /home/dan/git/uclinux-dist/tools/autotools-cache/build//$$; \
        cd /home/dan/git/uclinux-dist/tools/autotools-cache/build//$$; \
        CONFIG_SITE="" ../../configure -C; \
        mv config.cache /home/dan/git/uclinux-dist/tools/autotools-cache/build/config.cache
configure: creating cache config.cache
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for a thread-safe mkdir -p... /bin/mkdir -p
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
checking build system type... configure: error: cannot guess build type; you must specify one
make[1]: *** [/home/dan/git/uclinux-dist/tools/autotools-cache/build/config.cache] Error 1
make: *** [autotools-cache] Error 2
Then I tried "make distclean" to see if previous build attempts were causing issues, but since doings this I can't even configure the makefile:
dan@laptop:~/git/uclinux-dist$ make menuconfig
find vendors -mindepth 2 '(' -name .svn -prune ')' -o -type f -name Kconfig -print | sed 's:^:source ../:' > vendors/Kconfig
config/mkconfig > Kconfig
CC=cc CXX=c++ make -C /home/dan/git/uclinux-dist/config/kconfig conf
make[1]: Entering directory `/home/dan/git/uclinux-dist/config/kconfig'
cc -DCURSES_LOC="<ncurses.h>" -DKBUILD_NO_NLS  -c -o conf.o conf.c
as: unrecognised option '-Qy'
make[1]: *** [conf.o] Error 1
make[1]: Leaving directory `/home/dan/git/uclinux-dist/config/kconfig'
make: *** [/home/dan/git/uclinux-dist/config/kconfig/conf] Error 2
From tar'd sources, it fails on the lzotest part of the build:
Making install in lzotest
make[5]: Entering directory `/home/dan/build/uclinux/blackfin-linux-dist/lib/lzo/build-lzo-2.03/lzotest'
bfin-uclinux-gcc -DHAVE_CONFIG_H -I. -I/home/dan/build/uclinux/blackfin-linux-dist/lib/lzo/lzo-2.03/lzotest -I.. -I/home/dan/build/uclinux/blackfin-linux-dist/lib/lzo/lzo-2.03/include -I/home/dan/build/uclinux/blackfin-linux-dist/lib/lzo/lzo-2.03  -DEMBED -D__uClinux__ -I/home/dan/build/uclinux/blackfin-linux-dist  -mcpu=bf533-0.3 -DLZO_HAVE_CONFIG_H  -pipe -Wall -g -O2      -mcpu=bf533-0.3 -c /home/dan/build/uclinux/blackfin-linux-dist/lib/lzo/lzo-2.03/lzotest/lzotest.c
/bin/bash ../libtool --tag=CC --mode=link bfin-uclinux-gcc  -pipe -Wall -g -O2      -mcpu=bf533-0.3  -Wl,-elf2flt    -mcpu=bf533-0.3 -o lzotest  lzotest.o ../src/liblzo2.la
mkdir .libs
bfin-uclinux-gcc -pipe -Wall -g -O2 -mcpu=bf533-0.3 -Wl,-elf2flt -mcpu=bf533-0.3 -o lzotest lzotest.o  ../src/.libs/liblzo2.a
lzotest.o: In function `memchecker_check':
/home/dan/build/uclinux/blackfin-linux-dist/lib/lzo/lzo-2.03/lzotest/lzotest.c:663: undefined reference to `___assert_fail'
lzotest.o: In function `memchecker_init':
/home/dan/build/uclinux/blackfin-linux-dist/lib/lzo/lzo-2.03/lzotest/lzotest.c:637: undefined reference to `___assert_fail'
lzotest.o: In function `process_file':
/home/dan/build/uclinux/blackfin-linux-dist/lib/lzo/lzo-2.03/lzotest/lzotest.c:1051: undefined reference to `___assert_fail'
/home/dan/build/uclinux/blackfin-linux-dist/lib/lzo/lzo-2.03/lzotest/lzotest.c:1050: undefined reference to `___assert_fail'
lzotest.o: In function `main':
/home/dan/build/uclinux/blackfin-linux-dist/lib/lzo/lzo-2.03/lzotest/lzotest.c:1989: undefined reference to `___assert_fail'
lzotest.o:/home/dan/build/uclinux/blackfin-linux-dist/lib/lzo/lzo-2.03/lzotest/lzotest.c:2035: more undefined references to `___assert_fail' follow
collect2: ld returned 1 exit status
make[5]: *** [lzotest] Error 1
make[5]: Leaving directory `/home/dan/build/uclinux/blackfin-linux-dist/lib/lzo/build-lzo-2.03/lzotest'
make[4]: *** [install-recursive] Error 1
make[4]: Leaving directory `/home/dan/build/uclinux/blackfin-linux-dist/lib/lzo/build-lzo-2.03'
make[3]: *** [all] Error 2
make[3]: Leaving directory `/home/dan/build/uclinux/blackfin-linux-dist/lib/lzo'
make[2]: *** [lzo] Error 2
make[2]: Leaving directory `/home/dan/build/uclinux/blackfin-linux-dist/lib'
make[1]: *** [all] Error 2
make[1]: Leaving directory `/home/dan/build/uclinux/blackfin-linux-dist/lib'
make: *** [subdirs] Error 1
