AD7780 Output Code Format
Question asked by Dogan on Jun 22, 2012
Latest reply on Jun 28, 2012 by J.Gealon
Hi dear,
I am using AD7780 24-bit ADC for reading loadcell. But, not find the 32-bit output  value format of AD7780 in datasheet.
And I am need data/clock timing information.
My code is below. Where is wrong?
typedef union
    struct
        xBYTE PAT0:1;        // Status pattern bits. When the user read data from the Ad7780, an patter check can be performed.
        xBYTE PAT1:1;        // PAT1     PAT0
                            //  0        1   Indicates that the serial transfer from the ADC was performed correctly(default).
                            //  Ather, was not performed correctly.
        xBYTE GAIN:1;        // Gain bit,    0: gain = 128    1: gain = 1
        xBYTE ID0:1;        // ID Bits
        xBYTE ID1:1;        // ID1 = 0, ID0 = 1 : Indicate the ID number for the AD7780
        xBYTE ERR:1;        // Error bit,    1: an error occurred during conversion.(An error occurred when the analog inputs aoutside the range)
        xBYTE FILTER:1;        // Filter bit,     0: 16.7Hz  1: 10Hz
        xBYTE RDY:1;        // Ready bit,     0: a conversion is available.
    }Bits;
    xBYTE Value;
}AD7780_STATUS;
typedef union
    struct
        xBYTE :8;
        xBYTE :8;
        xBYTE :7;
        xBYTE Sign:1;
        xBYTE :8;
    }Bits;
     xBYTE Byte[4];
    xINT32 Value;
}AD7780_ADC;
void ad7780Init(void)
void ad7780Task(void)
            if(DOUT_RDY == 0)
                AD7780_STATS Status;
                   AD7780_ADC Adc;
                Adc.Value = 0;
                Adc.Byte[0] = ad7780ReadByte();
                Adc.Byte[1] = ad7780ReadByte();
                Adc.Byte[2] = ad7780ReadByte();
                Status.Value = ad7780ReadByte();
                if(Status.Bits.ERR == 1)
                    // An error occrred during conversion.
                    // (An error occrred when the analog inputs outside the range).
                    AD7780.State = AD7780_STATE_ERROR_INPUT_RANGE;
                    sm = SM_AD7780_RESET;
                else
                if(!(Status.Bits.PAT0 == 1 && Status.Bits.PAT1 == 0))
                    // Indicates that serial transfer from the ADC
                    // was not performed the correctly.
                    AD7780.State = AD7780_STATE_ERROR_SERIAL_TRANSFER;
                else
                if(Status.Bits.RDY == 0)
                    if(Adc.Bits.Sign == 1)
                        // Result is positive.
                        // Clear the sign bits.
                        Adc.Value &= 0x007FFFFF;
                    else
                        // Result is negative.
                        // Convert the binary complement.
                        Adc.Value |= 0xFF800000;
xBYTE ad7780ReadByte(void)
    xBYTE data;
     xINT bI;
    data = 0x00;
    for(bI = 0x0001; bI < 0x0100; bI <<= 1)
        SCLK = 0;
        asm("nop");
        asm("nop");
        SCLK = 1;
        asm("nop");
        asm("nop");
        if(DOUT_RDY)
            data |= bI;
    return data;
