ADXL345: Convert 16-Bit Twos Complement to Float
Question asked by JamesC on Jun 16, 2012
Latest reply on Jun 19, 2012 by jml
I am not clear on exactly how to convert DATAX0 and DATAX1 in register 0x32 into a float.  I have the following setup for the DATA_FORMAT register: range:  +/- 2G, D1/D0=00
justify: right justified w/sign extension, D2=0
full_res:  10-bit, D3 = 0
D7-D4 = 0000
comm = I2C
Here is a code snippet of what I am doing.  I am using a multi-byte read, as shown in another discussion to fetch the accel data.
// let's print out the data to see what we have
aX = ((signed int16) (accelIntArray[0] | accelIntArray[1]<<8));
aY = ((signed int16) (accelIntArray[2] | accelIntArray[3]<<8));
aZ = ((signed int16) (accelIntArray[4] | accelIntArray[5]<<8));
printf("AAAF  ");   // just a couple of bytes to mark the start of the data
printf("%4Ld %4Ld %4Ld  ", aX, aY,  aZ);
for(ix = 0; ix<6; ix++) {
  printf("%X ", accelIntArray[ix]);
    // read register 0x00 and check if we get 0xE5
myI2C_SingleByteRead(ADXL345, 0x00);
tempByte = i2cBuffer[0];      // after the read, this should have 0xE5
printf("%X", tempByte);
printf("\n\r");
Here is some output displayed in Hyperterminal.  "AAAF" are just some sync bytes from my PIC MCU.  "252  13  209"  are the aX  aY  aZ values in signed int, although I never see a sign change when I change the sensor orientation.  The next 6 bytes are the actual DATAX0, DATAX1...DATAZ0, DATAZ1 byte values.  And E5 is just the read result from a single byte read to register 0x00.
AAAF   252   13  209  FC FF 0D 01 D1 FF E5
AAAF   251    7  189  FB FF 07 01 BD FF E5
Any help deciphering this data would be greatly appreciated.  Thank you very much!
