BF609's performance
Question asked by liyq on Jun 16, 2012
Latest reply on Jun 19, 2012 by sonic
Recently, i got a BF609-EZKIT board, i installed uboot and uImage with 2012R1-BETA1-BF60X, and made some tests with this board, but i am confused with it's performance, i got the Dhrystones per Second only 384615.4, less than my bf537 stamp board about close to 50% ( bf537 stamp i got 657030.3) , i known 2012R1-BETA1 only used one core of BF609, but it still seems very slow than expected.
My question is, is this true for the bf609 single core performance so slow or i missed something. or, if you have a board and installed buildroot, please test it and post your test result, let us see how going wrong or something need to improve.
here is my test results (dhrystone is used 2012R1-BETA1 uImage built-in)
root:/mnt/usr/sbin> uname -a
Linux buildroot 3.3.0-ADI-2012R1-pre-00603-gfb4b3b1-dirty #2 Fri May 4 11:31:33 CST 2012 blackfin GNU/Linux
root:/mnt/usr/sbin> cat /proc/cpuinfo
processor       : 0
vendor_id       : unknown
cpu family      : Compiled for:0x27fe, running on:0x0000
model name      : ADSP-BF609 500(MHz CCLK) 100(MHz SCLK) (mpu off)
stepping        : 0
cpu MHz         : 500.000/100.000
bogomips        : 995.32
Calibration     : 497664000 loops
cache size      : 16 KB(L1 icache) 32 KB(L1 dcache) 0 KB(L2 cache)
dbank-A/B       : cache/cache
external memory : cacheable in instruction cache
external memory : cacheable (write-back) in data cache
icache setup    : 4 Sub-banks/4 Ways, 32 Lines/Way
dcache setup    : 2 Super-banks/4 Sub-banks/2 Ways, 64 Lines/Way
L2 SRAM         : 256KB
L2 SRAM         : uncacheable in instruction cache
L2 SRAM         : uncacheable in data cache
board name      : ADI BF609-EZKIT
board memory    : 131072 kB (0x00000000 -> 0x08000000)
kernel memory   : 130044 kB (0x00001000 -> 0x07f00000)
root:/mnt/usr/sbin> dhrystone 5000000
Dhrystone Benchmark, Version 2.1 (Language: C)
Program compiled without 'register' attribute
Execution starts, 5000000 runs through Dhrystone
Execution ends
Final values of the variables used in the benchmark:
Int_Glob:            5
        should be:   5
Bool_Glob:           1
        should be:   1
Ch_1_Glob:           A
        should be:   A
Ch_2_Glob:           B
        should be:   B
Arr_1_Glob[8]:       7
        should be:   7
Arr_2_Glob[8][7]:    5000010
        should be:   Number_Of_Runs + 10
Ptr_Glob->
  Ptr_Comp:          94915056
        should be:   (implementation-dependent)
  Discr:             0
        should be:   0
  Enum_Comp:         2
        should be:   2
  Int_Comp:          17
        should be:   17
  Str_Comp:          DHRYSTONE PROGRAM, SOME STRING
        should be:   DHRYSTONE PROGRAM, SOME STRING
Next_Ptr_Glob->
  Ptr_Comp:          94915056
        should be:   (implementation-dependent), same as above
  Discr:             0
        should be:   0
  Enum_Comp:         1
        should be:   1
  Int_Comp:          18
        should be:   18
Int_1_Loc:           5
        should be:   5
Int_2_Loc:           13
        should be:   13
Int_3_Loc:           7
        should be:   7
Enum_Loc:            1
        should be:   1
Str_1_Loc:           DHRYSTONE PROGRAM, 1'ST STRING
        should be:   DHRYSTONE PROGRAM, 1'ST STRING
Str_2_Loc:           DHRYSTONE PROGRAM, 2'ND STRING
        should be:   DHRYSTONE PROGRAM, 2'ND STRING
Microseconds for one run through Dhrystone:    2.6
Dhrystones per Second:                      384615.4
