v4l2 capture driver with mt9v032 sensor - ENOIOCTLCMD
Question asked by kai.ps on Jun 14, 2012
Latest reply on Jul 20, 2012 by ScottJiang
Hey everyone!
I've got another problem:
I'm trying to port the MT9V032 in the 2011R1 dist to work with the blackfin_video_capture driver (and the MT9V034 sensor, the predeccesor of the 032), but, in short, everything works fine until i try to open the /dev/video0, which returns "Unknown error 515" which stands for ENOIOCTLCMD.
As that's v4l2 for "no ioctl available" and the mt9v032 sensor driver is a pad based driver, I don't really know what's necessary to implement or if that's really the issue.
But here's the details:
2011R1 kernel on a custom board with a bluetechnix CM-BF548, config:
[*]   Media Controller API (EXPERIMENTAL)
<M>   Video For Linux
[*] V4L2 sub-device userspace API (EXPERIMENTAL)
[*]   Video capture adapters  --->
Encoders, decoders, sensors and other helper chips  --->
      <M> Micron MT9V032 sensor support
       <M>   Blackfin Video Capture Driver
I also changed the Chip-ID in the driver itself for correct identification and added to the board config in arch/...
The board config: http://pastebin.com/nvzYMPZi
What happens is the following:
root:/> modprobe i2c-bfin-twi
i2c-bfin-twi i2c-bfin-twi.0: Blackfin BF5xx on-chip I2C TWI Contoller,
regs_base@ffc00700
i2c-bfin-twi i2c-bfin-twi.1: Blackfin BF5xx on-chip I2C TWI Contoller,
regs_base@ffc02200
root:/> modprobe mt9v032
Linux video capture interface: v2.00
mt9v032_init: init
root:/> modprobe bfin_video_capture
ppi probe success
bfin_capture bfin_capture.0: v4l2 device registered
bfin_capture bfin_capture.0: video device registered as: video0
mt9v032_probe: probing
mt9v032 1-005c: Probing MT9V032 at address 0x5c
mt9v032 1-005c: MT9V032 detected at address 0x5c
bfin_capture bfin_capture.0: v4l2 sub device registered
root:/> ffmpeg -f video4linux2 -s 752x480 -i /dev/video0 /mnt/test.avi
FFmpeg version UNKNOWN, Copyright (c) 2000-2009 Fabrice Bellard, et al.
  built on Jun  6 2012 14:35:09 with gcc 4.3.5
  configuration: --prefix=/usr
--source-path=/home/kai/EDOD/
uclinux/blackfin-linux-dist/lib/ffmpeg/build/../ffmpeg-svn-20344
--target-os=linux --arch=bfin
--sysinclude=/home/kai/EDOD/uclinux/blackfin-linux-dist/staging/usr/include
--extra-ldflags=' -mcpu=bf548-any' --enable-static --enable-shared
--enable-gpl --enable-postproc --disable-ipv6 --disable-stripping
--cross-prefix=bfin-linux-uclibc-
  libavutil     50. 3. 0 / 50. 3. 0
  libavcodec    52.37. 0 / 52.37. 0
  libavformat   52.39. 2 / 52.39. 2
  libavdevice   52. 2. 0 / 52. 2. 0
  libswscale     0. 7. 1 /  0. 7. 1
  libpostproc   51. 2. 0 / 51. 2. 0
[video4linux2 @ 0x25f6010]Cannot open video device /dev/video0 :
Unknown error 515
/dev/video0: I/O error occurred
Usually that means that input file is truncated and/or corrupted.
root:/>
the log message gets posted in lib/ffmpeg/ffmpeg-svn-
<number>/libavdevice/v4l2.c in line 130 (rev 11114) or line 142 (rev
20344) as a response to an open
static int device_open(AVFormatContext *ctx, uint32_t *capabilities)
    struct v4l2_capability cap;
    int fd;
    int res;
    int flags = O_RDWR;
    if (ctx->flags & AVFMT_FLAG_NONBLOCK) {
        flags |= O_NONBLOCK;
    fd = open(ctx->filename, flags, 0);
    if (fd < 0) {
        av_log(ctx, AV_LOG_ERROR, "Cannot open video device %s : %s\n",
                 ctx->filename, strerror(errno));
        return -1;
What's the driver missing?
The open-ioctrl?
Thanks for your help,
Kai
