USB on BF548 EZ KIT
Question asked by laeeq on Jun 11, 2012
Latest reply on Jun 13, 2012 by Aaronwu
Dear All,
I am working on BF548 Ez Kit with uclinux. The issue is i am unable to get started with the USB. In the kernel options i have chosen ,
kernel options-> DD ->USB . The kernel i am using is Linux blackfin 3.0.8-ADI-2011R1 #281 Mon Jun 11 18:23:31 IST 2012 blackfin GNU
--- USB support        │ │
  │ │                                                             <M>   Support for Host-side USB        │ │
  │ │                                                             [*]     USB verbose debug messages        │ │
  │ │                                                             [*]     USB announce new devices        │ │
  │ │        *** Miscellaneous USB options ***        │ │
  │ │                                                             [ ]     USB device filesystem (DEPRECATED)        │ │
  │ │                                                             [ ]     USB device class-devices (DEPRECATED)        │ │
  │ │                                                             [ ]     Dynamic USB minor allocation        │ │
  │ │                                                             [ ]     USB runtime power management (autosuspend) and wakeup        │ │
  │ │                                                             [ ]   Rely on OTG Targeted Peripherals List        │ │
  │ │                                                             [ ]   Disable external hubs        │ │
  │ │                                                             <M>   USB Monitor        │ │
  │ │                                                             < >   Enable Wireless USB extensions (EXPERIMENTAL)        │ │
  │ │                                                             < >   Support WUSB Cable Based Association (CBA)        │ │
  │ │        *** USB Host Controller Drivers ***        │ │
  │ │                                                             < >   Cypress C67x00 HCD support        │ │
  │ │                                                             < >   OXU210HP HCD support        │ │
  │ │                                                             < >   ISP116X HCD support        │ │
  │ │                                                             < >   ISP 1760 HCD support        │ │
  │ │                                                             < >   ISP1362 HCD support        │ │
  │ │                                                             < >   SL811HS HCD support        │ │
  │ │                                                             < >   R8A66597 HCD support        │ │
  │ │                                                             < >   Host Wire Adapter (HWA) driver (EXPERIMENTAL)        │ │
  │ │        *** Enable Host or Gadget support to see Inventra options ***        │ │
  │ │                                                             < >   Inventra Highspeed Dual Role Controller (TI, ADI, ...)        │ │
  │ │        *** USB Device Class drivers ***        │ │
  │ │                                                             < >   USB Modem (CDC ACM) support        │ │
  │ │                                                             < >   USB Printer support        │ │
  │ │                                                             < >   USB Wireless Device Management support        │ │
  │ │                                                             < >   USB Test and Measurement Class support        │ │
  │ │        *** NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may ***        │ │
  │ │        *** also be needed; see USB_STORAGE Help for more info ***        │ │
  │ │                                                             <M>   USB Mass Storage support        │ │
  │ │                                                             [*]     USB Mass Storage verbose debug        │ │
  │ │                                                             < >     Realtek Card Reader support
and in the library options i have selected lsusb. Further after compiling and booting up when i run
find / -name "*usb*"
/sys/bus/usb
/sys/bus/usb/drivers/usbfs
/sys/kernel/debug/usb
/sys/kernel/debug/blackfin/usb
/sys/module/usbcore
/sys/module/usbcore/parameters/nousb
/sys/module/usbcore/parameters/usbfs_snoop
/sys/module/usbcore/drivers/usb:usbfs
/sys/module/usbcore/drivers/usb:hub
/usr/bin/lsusb
/usr/share/usb.ids
/lib/modules/3.0.8-ADI-2011R1/kernel/drivers/net/usb
/lib/modules/3.0.8-ADI-2011R1/kernel/drivers/net/usb/usbnet.ko
/lib/modules/3.0.8-ADI-2011R1/kernel/drivers/usb
/lib/modules/3.0.8-ADI-2011R1/kernel/drivers/usb/mon/usbmon.ko
/lib/modules/3.0.8-ADI-2011R1/kernel/drivers/usb/storage/usb-storage.ko
/lib/modules/3.0.8-ADI-2011R1/kernel/drivers/usb/core/usbcore.ko
Further the settings,
SW16 PIn3 -- ON
(ADSP-BF548 EZ-KIT Lite Hardware Reference  -- PG 77)
Jumper J11
USB Power for ADSP-BF548 processor      JP11 Pins 1 and 3                 JP11 Pins 2 and 4
        ON                                     ON
I connected a cable from the board to the host PC . Later i plan to check it a pen drive as well ( USB mass storage included) .
and then i run lsusb on the target board, it returns nothing . Then i run lsusb on the HOST PC ,  it displays other things but not anything specific to this board.Again i listed things with modprobe -l on the target board , it dsiplays,
modprobe -l
kernel/drivers/base/firmware_class.ko
kernel/drivers/input/ff-memless.ko
kernel/drivers/input/evbug.ko
kernel/fs/nls/nls_iso8859-1.ko
kernel/drivers/net/usb/cdc_ether.ko
kernel/fs/nls/nls_utf8.ko
kernel/drivers/i2c/i2c-mux.ko
misc/twi_smbus_test.ko
kernel/drivers/net/usb/cdc_ncm.ko
kernel/fs/fat/msdos.ko
kernel/drivers/scsi/scsi_wait_scan.ko
kernel/drivers/char/bfin-dma.ko
kernel/drivers/net/usb/asix.ko
kernel/fs/nls/nls_cp936.ko
kernel/drivers/mtd/tests/mtd_nandecctest.ko
kernel/drivers/net/usb/net1080.ko
kernel/fs/fat/fat.ko
misc/simple.ko
kernel/fs/jffs2/jffs2.ko
kernel/drivers/input/evdev.ko
kernel/fs/ext3/ext3.ko
If its a loadble module ( LKM) i can load it with modprobe usbcore  ?
Am i going somewhere wrong here ?
Any help is very much appreciated, Thanks
