adv7441a YPbPr input to RGB(AIN1,AIN2,AIN3), color isn't correct
Question asked by Gongfen on Jun 11, 2012
Latest reply on Jun 14, 2012 by GuenterL
Dear Sir,
I use adv7441a to capture YPbPr or VGA signal with a DB15 connector, YPbPr input to RGB(AIN1,AIN2,AIN3).
And the VGA input is good(RGBHV), but YPbPr isn't ok.
The hardware is:
G - AIN1 (SOG)   -- Y
B - AIN2     -- Pb
R - AIN3     -- Pr
My YPbPr script:(720P60 YPbPr input)
(0x21 is I2C 0x42>>1)
write i2c 0x21, addr=0x03,value=0x09
write i2c 0x21, addr=0x05,value=0x02
write i2c 0x21, addr=0x6b,value=0xe3
write i2c 0x21, addr=0x1d,value=0x40
write i2c 0x21, addr=0x3c,value=0xa8
write i2c 0x21, addr=0x47,value=0x0a
write i2c 0x21, addr=0x68,value=0xf2
write i2c 0x21, addr=0x7b,value=0x1d
write i2c 0x21, addr=0x7c,value=0x00
write i2c 0x21, addr=0xba,value=0xa0
write i2c 0x21, addr=0x85,value=0x19
write i2c 0x21, addr=0x06,value=0x07
write i2c 0x21, addr=0xc4,value=0x40
write i2c 0x21, addr=0x87,value=0xe6
write i2c 0x21, addr=0x88,value=0x72
write i2c 0x21, addr=0x8f,value=0x02
write i2c 0x21, addr=0x90,value=0x7c
write i2c 0x21, addr=0xab,value=0x2e
write i2c 0x21, addr=0xac,value=0xe0
write i2c 0x21, addr=0x91,value=0x10
You can see the attachment that I got.
If I set addr 0x68 to 0xF2, I got the picture is so green.
And if I set 0x68 to 0xF0, the picture is so dark.
The last picture is the source picture.
And VGA 1024x768 good script is this:
0x21 0x03 0x09 # Disable TOD
0x21 0x05 0x02 #; Prim_Mode =010b for GR
0x21 0x06 0x0c #; VID_STD=1100b for 1024x768 _@ 60
0x21 0x6B 0xe3 #; DE Out
0x21 0x1D 0x40 #; Disable TRI_LLC
0x21 0x3C 0xA8 #; SOG Sync level for atenuated sync, PLL Qpump to default
0x21 0x47 0x0A #; Enable Automatic PLL_Qpump and VCO Range
0x21 0x68 0xF0 #; Auto CSC , RGB Ou
0x21 0x7B 0x1D #; Turn off EAV and SAV codes
0x21 0xBA 0xA0 #; Enable HDMI and Analog in
0x21 0xF4 0x15 #; Max Drive Strength
So can you give me any script that YPbPr signal to connect AIN1,AIN2,AIN3 ?
Gongfen Qiu.
