BF548 ATAPI issues
Question asked by kai.ps on Jun 2, 2012
Latest reply on Jul 18, 2012 by kai.ps
Hey,
I am currently working on a custom board equipped with a bluetechnix CM-BF548 trying to get a IDE hard-disk up&running.
Unfortunately, it doesn't work completely and behaves quite strange!
It's runs witha uclinux 2011R1-RC3, but the latest svn gives the same behaviour.
Probing the module directly into the kernel results in quite a lot of ATA bus errors:
root:/> modprobe pata_bf54x
register bfin atapi driver
scsi0 : pata-bf54x
ata1: PATA max UDMA/66 irq 68
ata1.00: CFA: TRANSCEND, 20110519, max UDMA/66
ata1.00: 3913024 sectors, multi 0: LBA
ata1.00: configured for UDMA/66
blk_queue_max_segments: set to minimum 1
scsi 0:0:0:0: Direct-Access     ATA      TRANSCEND        2011 PQ: 0 ANSI: 5
sd 0:0:0:0: [sda] 3913024 512-byte logical blocks: (2.00 GB/1.86 GiB)
sd 0:0:0:0: [sda] Write Protect is off
sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
ata1.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6
ata1.00: BMDMA stat 0x4
ata1.00: failed command: READ DMA
ata1.00: cmd c8/00:08:00:00:00/00:00:00:00:00/e0 tag 0 dma 4096 in
         res 51/84:00:08:00:00/00:00:00:00:00/e0 Emask 0x10 (ATA bus error)
ata1.00: status: { DRDY ERR }
ata1.00: error: { ICRC ABRT }
ata1: soft resetting link
ata1: EH complete
ata1.00: limiting speed to UDMA/44:PIO4
[snip]
So I tried using the PIO mode, giving quite a nice log:
root:/> modprobe pata_bf54x bfin_atapi_mode=p
scsi0 : pata-bf54x
ata1: PATA max PIO4 irq 68
ata1.00: configured for PIO4
support DPO or FUA
sda: unknown partition table
sd 0:0:0:0: [sda] Attached SCSI disk
root:/>
but as shown in the log, the partition table can't be read and can't be succesfully changed with fdisk.
Using the mass-storage gadget I can partition and format the disk via the PC, the partition table is ok for the DSP after that, but only for the time to the next reboot. Modifying files on PC/DSP with a cross-check worked too.
I don't know whats wrong - the DMA errors suggest either a hardware problem or a kernel issue, but the PIO mode seems to work so far, which would lead me to the conclusion that the hardware is ok - is it?
That would be the most important part right now.
If the hardware would be faulty, all  the data I stored on it would be in some buffers...
Do you have any suggestions where the mistake could be or what checks I could do to find that out?
Thanks for your time,
Kai
