ADXL345 and the MSP430F2013 I2C communication problem
Question asked by RobertAttaway on May 30, 2012
Latest reply on Jun 13, 2012 by jml
I have set up an MSP430F2013 as the master and the ADXL345 as the slave.  I am following the standard setup using the Device ID address of 0x1D.
My scenario is this
Generate a start on the I2C bus
Send Write command for 0x1D - Result address = 0x3A
Ack is received from slave
Send address for tap register - 0x1D
Send data byte of 0x08
Send stop
Next to test my write I want to read the same back
Send Read command for 0x1D - Result address = 0x3B
Ack Received from slave
Request the data byte
0xFF is received instead of 0x08
I2C communication stops and never finishes out the final I2C sequence defined on page 18 of the ADXL345 datasheet. My end goal is to configure the part using the adxl345_init_data array once I confirm that reading and writing to the part is occurring properly.
Thank you for any help.
My code is as follows:
// REF#1-783040831
#include  <msp430x20x2.h>   // Processor File
#include "adxl345.h"        // ADXL345 Prototypes
#define TAP_DUR        0x10        // 625 us/LSB, 0x10=10ms
#define THRESH_TAP    0x08        // 62.5mg/LSB, 0x08=0.5g
#define TAP_AXES    XL345_TAP_Z_ENABLE    // 0x2a: TAP_Z enable
#define XL345_FORMAT    XL345_FULL_RESOLUTION | XL345_DATA_JUST_RIGHT | XL345_RANGE_16G
void GenerateStart(void);
void WriteSlaveBusAddress(char, int);
void ReceiveAckNackFromSlave(void);
void SendAckNackToSlave(char);
void SendDataToSlave(char data);
void RequestDataFromSlave(void);
char ReceiveDataFromSlave(void);
void StopCondition(void);
void Setup_USI_Master_TX (void);
void Setup_USI_Master_RX (void);
void TransmitToSlave(void);
void ReceiveFromSlave(void);
int I2C_State = 0, Bytecount, Transmit = 0;     // State variable
char byteFromSlave = 0x00;
const unsigned char adxl345_init_data[] =
    XL345_THRESH_TAP, THRESH_TAP,        // 0x1d: 62.5mg/LSB, 0x08=0.5g
    XL345_OFSX, 0x00,                // 0x1e: 0xff
    XL345_OFSY, 0x00,                // 0x1f: 0x05
    XL345_OFSZ, 0x00,                // 0x20: 0xff
    XL345_DUR, TAP_DUR,                // 0x21: 625 us/LSB, 0x10=10ms
    XL345_LATENT, 0x00,                // 0x22: no double tap
    XL345_WINDOW, 0x00,                // 0x23: no double tap
    XL345_THRESH_ACT, 0x20,            // 0x24: 62.5mg/LSB, 0x20=2g
    XL345_THRESH_INACT, 0x03,            // 0x25: 62.5mg/LSB, 0x03=0.1875g
    XL345_TIME_INACT, 0x02,            // 0x26: 1s/LSB, 0x02=2s
    XL345_ACT_INACT_CTL, 0x00,            // 0x27: no activity interrupt
    XL345_THRESH_FF, 0x00,            // 0x28: no free fall
    XL345_TIME_FF, 0x00,            // 0x29: no free fall
    XL345_TAP_AXES, TAP_AXES,            // 0x2a: TAP_Z enable
    XL345_BW_RATE, XL345_RATE_100,        // 0x2c
    XL345_POWER_CTL, XL345_STANDBY,        // 0x2d: standby while changing int
    XL345_INT_ENABLE, 0x00        ,    // 0x2e: disable
    XL345_INT_MAP, 0x00,            // 0x2f: all interrupts to INT1
    XL345_DATA_FORMAT, XL345_FORMAT,            // 0x31
    XL345_FIFO_CTL, 0x00,            // 0x38
    XL345_INT_ENABLE, XL345_SINGLETAP,            // 0x2e: single tap enable
    XL345_POWER_CTL, XL345_MEASURE,        // 0x2d: measure
    0x00                    // end of configuration
char ackNacks[] = {0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0, 0xC0};
int ackNackIdx = 0;
void main(void)
  WDTCTL = WDTPW + WDTHOLD;                 // Stop watchdog
  // USING 8MHZ AND CLOCK DIVIDER OF 0x20 to get 125kHz
  if (CALBC1_8MHZ ==0xFF || CALDCO_8MHZ == 0xFF)
    while(1);                               // If calibration constants erased
                                            // do not load, trap CPU!!
  BCSCTL1 = CALBC1_8MHZ;                    // Set DCO
  DCOCTL = CALDCO_8MHZ;
  P1OUT = 0xC0;                             // P1.6 & P1.7 Pullups, others to 0
  P1REN |= 0xC0;                            // P1.6 & P1.7 Pullups
  P1DIR = 0xFF;                             // Unused pins as outputs
  P2OUT = 0;
  P2DIR = 0xFF;
  TransmitToSlave();
  // The results of transmit to slave never produce the right result because the
  // Ack from the Device Bus Address never returns. It is always a Nack
  ReceiveFromSlave();
  if(byteFromSlave == 0x08) // This is just a test for me to know that the write to the
                            // slave address worked. It hasn't yet
    P1OUT |= 0x01;
    for(;;);
  USISRL = 0x00;                // Generate Start Condition...
  USICTL0 |= USIGE+USIOE;
  USICTL0 &= ~USIGE;
// this needs a parameter so on the receive the bus address can be a write on start
// and a read address on receive
void WriteSlaveBusAddress(char address, int READ_WRITE)
  USISRL =  (address << 1) + READ_WRITE;  // 0x91 Address is 0x48 << 1 bit + 1 for Read
  USICNT = (USICNT & 0xE0) + 0x08;        // Bit counter = 8, TX Address
  //USICTL1 &= ~USIIFG;
  // Save USISRL Value here
  USICTL0 &= ~USIOE;                    // SDA = input
  USICNT |= 0x01;                       // Bit counter = 1, receive (N)Ack bit
void SendAckNackToSlave(char ackNack)
  USICTL0 |= USIOE;                   // SDA = output
  USISRL = ackNack;                   // Send value to slave
  USISRL = data;                      // Send the specific data byte to slave
  USICNT |= 0x08;                     // Bit counter = 1, receive (N)Ack bit
  //USICTL0 &= ~USIOE;                  // SDA = input
  return USISRL;
  USISRL = 0x0FF;                   // USISRL = 1 to release SDA
  USICTL0 |= USIGE;                 // Transparent latch enabled
  USICTL0 &= ~(USIGE+USIOE);        // Latch/SDA output disabled
  _DINT();
  Bytecount = 0;
  Transmit = 1;
  USICTL0 = USIPE6+USIPE7+USIMST+USISWRST;  // Port & USI mode setup
  USICTL1 = USII2C+USIIE;                   // Enable I2C mode & USI interrupt
  USICKCTL = USIDIV_5+USISSEL_2+USICKPL;    // USI clk: SCL = SMCLK/128
  USICNT &= ~USI16B;                        // 8 bit words for I2C compatibility
  USICNT |= USIIFGCC;                       // Disable automatic clear control
  USICTL0 &= ~USILSB;                       // Use MSB
  USICTL0 &= ~USISWRST;                     // Enable USI
  USICTL1 &= ~USIIFG;                       // Clear pending flag
  _EINT();
  _DINT();
  Bytecount = 0;
  Transmit = 0;
  USICKCTL = USIDIV_5+USISSEL_2+USICKPL;    // USI clks: SCL = SMCLK/32 about 200kHz
  USICNT &= ~USI16B;
  USICTL0 &= ~USILSB;
  _EINT();
Service Routine should perform an entire write of one byte to the part
Then perform an entire read sequence reading the same address to which the data was sent
The result should be A = B
#pragma vector = USI_VECTOR
__interrupt void USI_TXRX (void)
  if(Transmit==1)
    switch(__even_in_range(I2C_State,12))
      //Tasks to write to the slave
      //01 Generate a start command on the I2C bus
      case 0:
        GenerateStart(); // 0
        // Then the slave address for the device for which we will communicate
        WriteSlaveBusAddress(0x1d, 0);
        I2C_State = 2;
        break;
      //03 Receive the Ack/Nack from the I2C bus
      case 2:
        ReceiveAckNackFromSlave(); // 2
        I2C_State = 4;
        break;
      //04 Send register address
      case 4:
        SendDataToSlave(0x1d); // 4 - A register's address is just data
        I2C_State = 6;
        break;
      //05 Receive Ack/Nack from I2C bus
      case 6:
        I2C_State = 8;
        break;
      //06 Send data to address sent in 4
      case 8:
        SendDataToSlave(0x08);
        I2C_State = 10;
        break;
      //07 Receive Ack/Nack from I2C bus
      case 10:
        I2C_State = 12;
        break;
      //8.1 If no more data send stop command
      //8.2 If more data go to step 6 and send another data byte
      case 12:
        StopCondition();
        I2C_State = 0;
        break;
  else if(Transmit == 0)
    switch(__even_in_range(I2C_State,18))
      //Tasks to receive data from slave
      case 0:
        GenerateStart();
        I2C_State = 2;
        break;
      case 2:
        I2C_State = 4;
        break;
      case 4:
        I2C_State = 6;
        break;
      case 6:
        I2C_State = 8;
        break;
      //06 Generate a start command on the I2C bus
      case 8:
        GenerateStart();
        WriteSlaveBusAddress(0x1d, 1); // Slave address and read bit
        I2C_State = 10;
        break;
      //08 Receive Ack/Nack from I2C bus
      case 10:
        I2C_State = 12;
        break;
      //09 Receive data into USI register
      case 12:
        //USICTL0 |= USIGE; // We are going to try and force the latch transparency to pull SDA low
        //USICTL0 &= ~USIGE; // http://www.i2c-bus.org/analysing-obscure-problems/data-bytes-from-slave-are-0xff/
        RequestDataFromSlave();
        I2C_State = 14;
        break;
      case 14:
        // This code does everything I expect now up until this point
        // When the USI Interrupt Pulls the 8 bits from the slave address
        // instead of getting 0x08 I get 0xFF and then case 16 and 18 never
        // get called
        byteFromSlave = USISRL; //ReceiveDataFromSlave();
        I2C_State = 16;
        break;
      //10 Send Ack/Nack (Ack to read again Nack to stop)
      case 16:
        SendAckNackToSlave(0x01); // 0x00 is Ack and 0x01 is Nack
        I2C_State = 18;
        break;
      //10.1 If Ack go to 09
      //10.2 If Nack send final stop command
      case 18:
        StopCondition();
        I2C_State = 0;
        break;
    USICTL1 &= ~USIIFG; // This will be commented out of each function that the ISR calls
        After the service interrupt is used by Main for one read and one write the
        value in the byteFromSlave must be 0x08 because that is what we sent to
        that address during the write process
  Setup_USI_Master_TX();
  //P1OUT ^= 0x01;
  USICTL1 |= USIIFG;                      // Set flag and start communication
  //LPM0;                                   // CPU off, await USI interrupt
  for (long i = 0; i < 40000; i++);         // Delay between comm cycles
  //ackNacks[ackNackIdx++] = USISRL; // capture the last ackNack for the write sequence
  Setup_USI_Master_RX();
