ADV7611: Internal EDID stays disabled
Question asked by khristozov on May 30, 2012
Latest reply on Jan 9, 2014 by melisaelzer
I'm trying to setup the ADV7611 to use the internal EDID just like this thread describes http://ez.analog.com/thread/9106
After the initialization sequence I always read the flag EDID_A_ENABLE_CPU = 0x0, which means that the internal EDID stays disabled.
I can read back the loaded EDID at address 0xA0, but not over the HDMI cable.
Is there any contraint (like timing) which has to be met to get the internal EDID enabled? I already ensured that no other device is connected to the DDC bus.
On our hardware the ADV7611 receiver passes the RGB video signal to an FPGA for further processing.
Here is the initialization sequence I use
98 FF 80 ; I2C reset
98 F4 80 ; CEC
98 F5 7C ; INFOFRAME
98 F8 4C ; DPLL
98 F9 64 ; KSV
98 FA 6C ; EDID
98 FB 68 ; HDMI
98 FD 44 ; CP
64 77 00 ; Disable the Internal EDID
0x6C 00 ... followed by 256 edid bytes
64 77 00 ; Set the Most Significant Bit of the SPA location to 0
64 52 20 ; Set the SPA for port B.
64 53 00 ; Set the SPA for port B.
64 70 9E ; Set the Least Significant Byte of the SPA location
64 74 03 ; Enable the Internal EDID for Ports
98 01 06 ; Prim_Mode =110b HDMI-GR
98 00 01 ; Set VID_STD to SVGA 800x600@60Hz
98 02 F2 ; RGB
98 03 40 ; 24 bit SDR 444 Mode 0
98 05 28 ; AV Codes Off
98 06 A6 ; Positive VS & HS polarity
98 0B 44 ; Power up part
98 0C 42 ; Power up part
98 14 7F ; Max Drive Strength
98 15 80 ; Disable Tristate of Pins
98 19 83 ; LLC DLL phase
98 33 40 ; LLC DLL enable
44 BA 01 ; Set HDMI FreeRun
64 40 81 ; Disable HDCP 1.1 features
68 9B 03 ; ADI recommended setting
68 C1 01 ; ADI recommended setting
68 C2 01 ; ADI recommended setting
68 C3 01 ; ADI recommended setting
68 C4 01 ; ADI recommended setting
68 C5 01 ; ADI recommended setting
68 C6 01 ; ADI recommended setting
68 C7 01 ; ADI recommended setting
68 C8 01 ; ADI recommended setting
68 C9 01 ; ADI recommended setting
68 CA 01 ; ADI recommended setting
68 CB 01 ; ADI recommended setting
68 CC 01 ; ADI recommended setting
68 00 00 ; Set HDMI Input Port A
68 83 FE ; Enable clock terminator for port A
68 6F 0C ; ADI recommended setting
68 85 1F ; ADI recommended setting
68 87 70 ; ADI recommended setting
68 8D 04 ; LFG
68 8E 1E ; HFG
68 1A 8A ; unmute audio
68 57 DA ; ADI recommended setting
68 58 01 ; ADI recommended setting
68 75 10 ; DDC drive strength
Thanks
Konstantin
