ADV7341
Question asked by OzLeM on May 28, 2012
Latest reply on Sep 25, 2012 by DaveD
I try to configure ADV7341 for NTSC and PAL. I used these settings. Are they true settings? It's very important and urgent.
Thank you...
CVBS (NTSC) - AVIDOUT 16 Bit 4:2:2
541702Reset Encoder
540080Power up DAC4 and PLL
540180SD input only. Y/C/S Bu swap setting
548010SSAF Luma filter enabled, NTSC Mode
548241DAC4 CVBS Out, DAC1 Y Out
548406Enable SFL
54881816 bit input enabled. Gamma correction disabled. DNR disabled. Noninterlaced mode disabled. Double buffering disabled.
548A04SD Timing Mode2 (HS and VS Mode) Default mode is Mode0
CVBS (PAL) - AVIDOUT 16 Bit 4:2:2
541702Reset Encoder
540180SD input only. Y/C/S Bus swap setting
548011SSAF Luma filter enabled, Standard PAL B/G/D/H/I
548406Enable SFL
548CCBPAL Fsc setting
548D8APAL Fsc setting
548E09PAL Fsc setting
548F2APAL Fsc setting
