Help me to use ADuC7024 Temp Sensor
Question asked by TiagoR on May 25, 2012
Latest reply on May 29, 2012 by AudeR
Hi,I'm just learning how to use ADuC and I want you to help me. Because I don't know how to understand all the code especially when it refers to ADCCON and ADCCP. Someone could explain a little bit?!. I'm having too some difficultis related to compile the code below. As you might know, this code it's aviable on datasheet pg 43. I tried to compile this code in KEIL 4, but appears some warnings such as:
temp sensor.c(8): warning:  #223-D: function "delay" declared implicitly
temp sensor.c(22): warning:  #223-D: function "floor" declared implicitly
temp sensor.c(32): warning:  #223-D: function "printf" declared implicitly
BR
Thanks!
#include<aduc7024.h>
int main(void)
float a = 0;
short b;
ADCCON = 0x20; // power-on the ADC
delay(2000);
ADCCP = 0x10; // Select Temperature
//Sensor as an input to the ADC
REFCON = 0x01; // connect internal 2.5Vreference // to Vref pin
ADCCON = 0xE4; // continuous conversion
while(1)
while (!ADCSTA){};
// wait for end of conversion
b = (ADCDAT >> 16);
// To calculate temperature in °C, usethe formula:
a = 0x525 - b;
// ((Temperature = 0x525 - SensorVoltage) / 1.3)
a /= 1.3;
b = floor(a);
printf("Temperature: %doC\n",b);
return 0;
