Trouble in reading unprocessed acceleration data from ADIS16227
Question asked by jagadeepram on May 10, 2012
Latest reply on Jun 4, 2012 by NevadaMark
HI All,
         I see unexpected result while reading the raw (unprocessed) acceleration data from ADIS16227 device. I read the data by placing device is static position, so that only acceleration component is gravity on z-axis. Data range is selected from 0 to 70 g
Thus I need to get the acceleration value on 3 axis as
x-axis: 0x0000
y-axis: 0x0000
z-axis: 0xfe5c or 0x01a4 (which corresponds to +/- 1 g ).
But what I received from the device is below.
x-axis: 0x0002
y-axis: 0x0002
z-axis: 0x0002
I expect one of the value to be high compare to other two because of gravity.  Blow is the pseudo code used to get the acceleration data.
I am able to set the rec_ctrl register and able to read the same value as well as prod id, so that SPI communication is out of suspect.
main()
     spi_write(software_reset);
     delay(); // delay till 500 ms for software reset.
     spi_write(REC_CTRL, 0x0832); // select SR3,0-70g, storage method: N/A, manual time mode.
     delay();
     spi_write(GLOB_CMD,0x0800);// start recording
      while(1)
         print( spi_read(x_buff));
          delay();
          while( spi_read(diag_stat)&0x0080==0); // wait till data is ready
          print(spi_read(y_buff));
          delay();
          print(spi_read(z_buff));
          delay();
       The sentence "In manual time mode, each axis' record contains 512 samples for each axis" at page no 16, 1st para in the data sheet is confusing a bit. Is that mean the current acceleration data is queued in buffer and read out only after 512 read instructions of the buffer ?
My Requirement is to get the unprocessed acceleration data at a given instant. If I vibrate the device ,I should see corresponding changes in the acceleration value from the device at that instant.
Please help me in getting my requirement.
Jagadeepram.
