ADV7441A-HDMI Clock lock
Question asked by lemonchen on May 8, 2012
Latest reply on May 9, 2012 by DaveD
//720P HDMI receiver
42 03 0C ; Disable TOD
42 05 06 ; Prim_Mode =0110b HDMI
42 1D 40 ; Disable TRI_LLC
42 37 00 ; Disable PCLK
42 68 F0 ; Auto CSC , YPrPb out
42 6B D2 ; Enable 656 mode
42 BA A0 ; Enable HDMI and Analog in
42 C8 08 ; Digital Fine Clamp Start position
62 F0 10 ; ADI Recommended Write
62 F1 0F ; ADI Recommended Write
62 F4 20 ; ADI Recommended Write
//audio
6A 15 EC ; Disable these mute mask bits
6A 1C 49 ; Set MCLKOUT to output 256fs
6A 1D 04 ; & Set Unmute Delay to 1_5 sec.
6A 5A 01 ; Reset Audio Pll
//output embedded video
42 0F bit[4]=0 //set PWRSAV
42 85 bit[4:3]=01b  //Manual setting: separate HS and VS on the respective pins
42 85 bit[0]=1 //Outputs synchronous
// output selection MODE6
        err = adv7441_i2c_read_reg(&adv7840_channel_info[ch_id].i2c_dev.client,0X21,0x6b, &val);
        val &= ~(0x0f);
        val |= 0x03;
        err = adv7441_i2c_write_reg(&adv7840_channel_info[ch_id].i2c_dev.client,0x21 ,0x6b ,val );
        err = adv7441_i2c_read_reg(&adv7840_channel_info[ch_id].i2c_dev.client,0X21,0xC9, &val);
        val &= ~(0x18);
        err = adv7441_i2c_write_reg(&adv7840_channel_info[ch_id].i2c_dev.client,0x21 ,0xC9 ,val );
We config the ADV7441A board as the above values.
But there is some problems on  the HDMI port. DVI and HDMI video are all tested.
For example,
    HDMI Map, Address 0x04 [3] sometimes is "0", means No TMDS clock detected on port A.
    HDMI Map, Address 0x068 [7] always is "0", means"Vertical sync filter has not locked and vertical sync parameters are not valid."
Please give me some suggestions, thank you all.
By the way:
We now can receive VGA and CVBS signal with ADV7441A from 720x576 to 1920x1080.
The board is designed by ourselves.
We have layout 2 borad for this project, but still can't resolve this problem.
We have used SiI9135 to receive DVI and HDMI video, it is ok, so I think our layout is OK.
