Can I use FLOW_STOP with 2D DMA
Question asked by MartyC on May 8, 2012
Latest reply on May 9, 2012 by CraigG
I am using the BF527.
I need to receive a buffer that is 256 * 2048 from the SPI port.  I would like to get an interrupt every 2048 bytes that is received.
Currently I receive the first 2048 bytes, and then in the ISR I clear the DMA_DONE bit in the status register.
Then I get the second 2048 bytes and I do not get any more data after that.
Why does the DMA stop after the second transfer?
static const u32 kNUM_BLOCKS = 256;
u8    m_DMA_Buffer[kNUM_BLOCKS * SPI_BUFFER_SIZE];
VDK::PushCriticalRegion();
    *pDMA7_CONFIG           &= ~DMAEN;
    *pDMA7_START_ADDR  = &m_DMA_Buffer[0];
    *pDMA7_X_COUNT          = SPI_BUFFER_SIZE;
    *pDMA7_X_MODIFY         = 1;
    *pDMA7_Y_COUNT          = kNUM_BLOCKS;
    *pDMA7_Y_MODIFY         = 1;
    *pDMA7_PERIPHERAL_MAP   = PMAP_SPI;
    *pDMA7_CONFIG           = DMA2D | WNR | FLOW_STOP | DI_EN | DI_SEL | WDSIZE_8;
VDK::PopCriticalRegion();
  *pSPI_STAT = ( SPIF |  MODF );
  *pSPI_CTL     = (MSTR | RDBR_DMA);
  *pSIC_IMASK0 = IRQ_DMA7;   // DMA Channel 7 (SPI) Interrupt
  *pDMA7_CONFIG |= DMAEN; // Turn on the SPI DMA Controller
  *pSPI_CTL     |= SPE;   // Enable the SPI interface
EX_INTERRUPT_HANDLER(DAQ_ISR_IVG13)
  u64 irqStatus = 0;
   if (*pSIC_ISR0 & IRQ_DMA7)
     if (*pDMA7_IRQ_STATUS & DMA_DONE) {
       *pDMA7_IRQ_STATUS = DMA_DONE;
       irqStatus |= VOCT::DAQ_Base::INTERRUPT_SPI_DMA7_DONE;
     if (*pDMA7_IRQ_STATUS & DMA_ERR)  {
       *pDMA7_IRQ_STATUS = DMA_ERR;
       irqStatus |= VOCT::DAQ_Base::INTERRUPT_SPI_DMA7_ERR;
