ADV7611 setup help
Question asked by dubrcm on May 3, 2012
Latest reply on May 4, 2012 by mattp
I have a board which has a ADV7611 chip on it and I need to verify that it is working.  So far I've connected it up and can issue i2c commands with
i2c_smbus_read_word_data(file, 0xEA) and it returns with the id 0x5120 which suggests the chip is up.
now I want to set it up, so I use the recommended setting:
  res = i2c_smbus_write_byte_data(file, 0xF4, 0x80); // CEC Map
  res = i2c_smbus_write_byte_data(file, 0xF5, 0x7C);
  res = i2c_smbus_write_byte_data(file, 0xF8, 0x4C);
  res = i2c_smbus_write_byte_data(file, 0xF9, 0x64);
  res = i2c_smbus_write_byte_data(file, 0xFA, 0x6C); // EDID Map
  res = i2c_smbus_write_byte_data(file, 0xFB, 0x68); // HDMI Map
  res = i2c_smbus_write_byte_data(file, 0xFD, 0x44); // CP Map
  res = i2c_smbus_write_byte_data(file, 0x6C, 0x0);
and the HDMI Map with settings from section 1.2 of the RecSettings doc.
I just want it start outing something, so I just picked a mode and set it to freeRun
  ioctl(file, I2C_SLAVE_FORCE, 0x98);
  res = i2c_smbus_write_byte_data(file, 0x00, 0x0); // VID_STD
  res = i2c_smbus_write_byte_data(file, 0x01, 0x05); // PRIM_MODE
  ioctl(file, I2C_SLAVE_FORCE, 0x44);
  res = i2c_smbus_write_byte_data(file, 0xC9, 0x1);
  res = i2c_smbus_write_byte_data(file, 0xBF, 0x1);
Is this setting correct so far?
If this works, I would be getting data out of the Digital video output pins, and possibly a clock signal for the LLC pin?
any feedback would be useful.
David
