bf535 memory dma problem
Question asked by novemer on May 1, 2012
Latest reply on May 2, 2012 by novemer
hi all:
     i'm a new to use blackfin dsp.now i'm using bf535.there is a problem that how to use the memory dma to transfer data.i want to copy data of sdram to asynchronous memory( was connected to a fpga) by dma.here is the code:
#define pFpgaAddr  (unsigned long *)0x20000000
#define pSramAddr  (unsigned long *)0x0
pNext =pL2_BASE+10;
  *pNext =0x0;
  unsigned char *dma_decr0;
  unsigned char *dma_decr1;
  dma_decr0 =0xff800d80;
  dma_decr1 =0xff800d90;
*(dma_decr0+2) =0xa;
  *(dma_decr0+4) =0x0;
  *(dma_decr0+6) =0x2000;
  *(dma_decr0+8) =pNext;
*(dma_decr1+2) =0xa;
  *(dma_decr1+4) =0x0;
  *(dma_decr1+6) =0x0;
  *(dma_decr1+8) =pNext;
*dma_decr0 =0x8001;
  *dma_decr1 =0x8001;
  *pMDS_DND =0x0d80;
  *pDMA_DBP =0xff80;   //dma descriptor base pointer reg
  *pMDD_DND =0x0d90;
  *pMDD_DCFG =0x8009;   //dma config
  *pMDS_DCFG =0x8009;   //dma config
i don't know the meaning of configration bit0(dma enabe) and bit15(descriptor block ownership).does it set bit15 first then set bit0 or bit0 first?
thanks
