ADSP 21469 SPI Slave Boot
Question asked by Hfuhrhurr on Apr 20, 2012
Latest reply on Jun 4, 2012 by Mitesh
Hi all,
I have a problem with booting the ADSP 21469 from an ARM Cortex M3 processor (Stellaris LM3S).
The DSP is clocked by a 12.288 MHz Oscillator and CLK_CFG1-0 is 1 0, so the DSP is running at 16x12.288MHz
Here's what I am doing
  • Reset the DSP
  • wait for RESETOUT being deasserted
  • for safety, wait another microsecond
  • transfer data to the DSP via the SSI (SPI) interface
SSI Settings:
SSI_FRF_MOTO_MODE_3 (CPHASE and CPOL = 1)
16 bit wordlength
SPI rate 50kHz (500kHz and 5MHz also tested)
  • transferred data
0x66AA, 0x22CC, 0x4488
0xBB33, 0xDD55, 0x11EE
which is bitreversed
0x5566, 0x3344, 0x1122
0xBBCC, 0x99AA, 0x7788
Only these 6x16-bit words are transferred.
According to the 16-bit packing rules, this should result in
0x112233445566
0x778899AABBCC
When I look into the P-MEM of the DSP at 0x8c000 after this procedure, I see
Dumping range 0x0008c000 - 0x0008c00b by 1 (Hexadecimal)...
    0x556655660000
    0x112233443344
    0xBBCCBBCC1122
    0x778899AA99AA
    0x556655667788
    0x112233443344
    0xBBCCBBCC1122
    0x778899AA99AA
    0x000000000000
    0x000000000000
    0x000000000000
    0x000000000000
It looks like the values itself are transferred correctly, however they are scrambled and duplicated in the buffer.
The SPI signals look like this
What you see in the screenshot are the first two 16-bit words 0x5566 and 0x3344.
I modified the pause between two 16-bit transfers from almost no pause at all to long pauses as seen in the image, makes no difference.
Does anyone have an idea what's wrong?
EDIT: I had a closer look at the timing between the SPI DS and SPICLK
The two signals at the top are SPIDS (yellow) and SPICLK. There's exactly one half SPICLK cycle between asserting SPIDS and the first CLK edge. Would that be sufficient?
Rainer
