BF514 SDRAM odd memory address problem
Question asked by trineary on Apr 15, 2012
Latest reply on Jun 2, 2012 by trineary
I've got a problem with with my SDRAM.  I've allocated some space in the SDRAM, I run through a for loop where I write 50 values to sequential memory and then read them back out.  The even memory addresses write/read back the number I expect, but the odd memory addresses do not.  Has anyone seen anything like this?
Here are some of the details of my configuration:
Hardware:
I'm using the BF514F and a 32MB SDRAM MT48LC32M8A2P.
SDRAM -
  • Configuration - 8 Meg x 8 x 4 banks
  • Row addressing - 8K A[12:0]
  • Bank addressing - 4 BA[1:0]
  • Column addressing - 1K A[9:0]
Memory initialization in the .ldf:
      sdram0_bank2
         INPUT_SECTION_ALIGN(4)
         // ... (more statements, but removed for this posting)
         INPUT_SECTIONS($OBJECTS(mem_test))                               //Memory I've defined
      } > MEM_SDRAM0_BANK2
SDRAM register initialization
void InitializeSDRAM()
    //Initialize registers to enable use of sdram
    *pEBIU_SDRRC  = 800;
    *pEBIU_SDGCTL = 0x0492998D;
    *pEBIU_SDBCTL = 0x23;
    printf(" -> SDRAM Initialized ... \n");
Test Code
section("mem_test") unsigned char memTest4[500];
void TestMem()
int i;
int ctr=0;
printf("memory test\n");
for(i=0; i<50; i++)
  memTest4[i] = i;
  ctr++;
for(i=0; i<50; i++)
  printf("(0x%x, %d, %d), \n", &memTest4[i], i, memTest4[i]);
printf("\n");
Test Results
memory test
(0x1000000, 0, 0),
(0x1000001, 1, 49),
(0x1000002, 2, 2),
(0x1000003, 3, 49),
(0x1000004, 4, 4),
(0x1000005, 5, 49),
(0x1000006, 6, 6),
(0x1000007, 7, 49),
(0x1000008, 8, 8),
(0x1000009, 9, 49),
(0x1000029, 41, 49),
(0x100002a, 42, 42),
(0x100002b, 43, 49),
(0x100002c, 44, 44),
(0x100002d, 45, 49),
(0x100002e, 46, 46),
(0x100002f, 47, 49),
(0x1000030, 48, 48),
(0x1000031, 49, 49),
..End test results
In the results, the hex number is the memory address, followed by the index of the memory array, followed by the data value read from the array/memory.  The index and the number read should be the same.  Why do all odd memory locations show the number written to the last odd memory location (49)?
Does anyone have any idea as to what would cause this???  I've double checked our schematic and it appears that all the pins are hooked up according to the data sheet.
Thanks for any insight,
Patrick
