SPI config in ezkit.c for spidev on bus 1
Question asked by MarkBishop on Apr 12, 2012
Latest reply on Apr 13, 2012 by Aaronwu
On a BF548 I am trying to setup spidev correctly in the linux board file (ex, ezkit.c).
I am using SPI bus 1, and only one chip select (SPISS1 - PG11).
Here is the error in the bootup
spi spi1.0: Warning: SPI CPHA not set: Slave Select not under software control!
See Documentation/blackfin/bfin-spi-notes.txt
spi spi1.0: peripheral_request() error
bfin-spi bfin-spi.1: can't setup spi1.0, status -19
bfin-spi bfin-spi.1: can't create new device for spidev
The bfin-spi-notes.txt mentions to use MODE_3 instead of MODE_0.
                .modalias = "spidev",
                .max_speed_hz = 3125000,     /* max spi clock (SCK) speed in HZ */
                .bus_num = 1,
                .chip_select = 0,
                .mode = SPI_MODE_3,
static struct bfin5xx_spi_master bf54x_spi_master_info1 = {
        .num_chipselect = 1,
        .enable_dma = 1,  /* master has the ability to do dma transfer */
        .pin_req = {P_SPI1_SCK, P_SPI1_MISO, P_SPI1_MOSI, 0},
Any idea what I am missing?
