wdth_cap timer mode problem  adsp21364
Question asked by brenneke on Apr 3, 2012
Latest reply on Apr 5, 2012 by Harshit.Gaharwar
Hello! I need to measure 300-500 ns continuous pulses with 1-20 us periods.
N-1 Pulse width and period may be different with N pulse width and period.
So as I understand I should use width capturing mode. My code is:
void timer_interrupt(int sig_int)
   period = * (volatile int *) TM1PRD;
    width  = * (volatile int *) TM1W;
PERIODS[TIMES_pntr] = period;
WIDTHS [TIMES_pntr] = width;
TIMES_pntr++;
TIMES_pntr = TIMES_pntr % PULSE_NUMBER;
    NOP();
    NOP();
    NOP();
main () {
interrupt(SIG_GPTMR1,timer_interrupt);
*(volatile int *) TM1CTL = TIMODEW|
PULSE|
IRQEN|
PRDCNT;
    NOP();
    NOP();
    * (volatile int *) TMSTAT = TIM1EN;            /* enable timer 1 */
I generate test pulses by using core timer and FLAG1 pin then route this signal to timer1 DAI pin externally. All I have is the first value of the first pulse period in  all cells of PERIODS[] and width in all cells of WIDTHS[]. I use EZ-kit evaluation board.
I need an advice! Thank you.  Source code attached.
