Configuring right justified ad1836 packets on EzKitbf561
Question asked by willrobot on Mar 27, 2012
Latest reply on Apr 12, 2012 by Prashant
I'm trying to configure right justified packets on the ad1836 register. I do not had any luck though, I always get the packets left justified. As well is I2S right or left justified?
the configuration of the ad1836 is as in talkthrough: (whe I try right shift nothing change)
volatile short sCodec1836TxRegs[CODEC_1836_REGS_LENGTH] =
                                        DAC_CONTROL_1   | 0x000, //was 0x020
                                        DAC_CONTROL_2   | 0x000,
                                        DAC_VOLUME_0    | 0x3ff,
                                        DAC_VOLUME_1    | 0x3ff,
                                        DAC_VOLUME_2    | 0x3ff,
                                        DAC_VOLUME_3    | 0x3ff,
                                        DAC_VOLUME_4    | 0x3ff,
                                        DAC_VOLUME_5    | 0x3ff,
                    ADC_CONTROL_1   | 0x000, //was 0x000/1\
1B
                                        ADC_CONTROL_2   | 0x180,//was 180/140
                                        ADC_CONTROL_3   | 0x000
    // reset codec
    // set PF15 as output
    SSYNC();
    // clear bit to enable AD1836
    bfin_write_FIO0_FLAG_S(bfin_read_FIO0_DIR() | 0x8000);
    SSYNC();
    // wait to recover from reset
    for (wait_reset=0; wait_reset<0xf000; wait_reset++);
   // Enable PF4
    bfin_write_SPI_FLG(0x1010);
    // Set baud rate SCK = HCLK/(2*SPIBAUD)
    bfin_write_SPI_BAUD(0x0010);
    // configure spi port
    // SPI DMA write, 16-bit data, MSB first, SPI Master
    bfin_write_SPI_CTL(TIMOD_DMA_TX | SIZE | MSTR);
// Set up DMA2 channel 4 to SPI transmit
    bfin_write_DMA2_4_PERIPHERAL_MAP(0x4000);
    // Configure DMA2 channel4
    // 16-bit transfers
    bfin_write_DMA2_4_CONFIG(bfin_read_DMA2_4_CONFIG() | 0x0004) ;
    // Start address of data buffer
    bfin_write_DMA2_4_START_ADDR((void *)sCodec1836TxRegs);
    // DMA inner loop count
    bfin_write_DMA2_4_X_COUNT(CODEC_1836_REGS_LENGTH);
// Inner loop address increment
    bfin_write_DMA2_4_X_MODIFY(2);
// enable DMAs
    bfin_write_DMA2_4_CONFIG(bfin_read_DMA2_4_CONFIG() | 0x0001) ;
    // enable spi
    bfin_write_SPI_CTL(bfin_read_SPI_CTL() | 0x4000);
    SSYNC();
    // wait until dma transfers for spi are finished
    for (wait_dma_finish=0; wait_dma_finish<0xaff; wait_dma_finish++);
    // disable spi
    bfin_write_SPI_CTL(0x0000);
I think that is what it should be done.... obviously I'm missing something in the configuration
