oprofile on BlackFin uClinux
Question asked by jgraley1 on Mar 26, 2012
Latest reply on Apr 5, 2012 by sonic
Hi
I am trying to enable oprofile according to the instructions at http://docs.blackfin.uclinux.org/doku.php?id=linux-kernel:oprofile
I believe the kernel hooks are going in OK, and that the oprofile project under user/blkfin_apps/opprofile/ is being built, but the resulting user-space executables (opreport, opcontrol etc) are not appearing anywhere in the target uClinux system. I am investigating but cannot see how these executables are supposed to get onto the target. Here's what I have found:
- There is a makefile (lower-case m) in user/blkfin_apps/opprofile/ which appears to be for integration into Linux. It has a "romfs" target, but I cannot see how this gets invoked by the Linux build system. I cannot invoke it directly without knowing what environment variables need to be set.
- The uclinux build process produces rootfs.cramfs, which I suspect should contain apps that will appear in the filesystem on the target. I cannot find where in the makefile system rootfs.cramfs is created, and I cannot see which sub-directory it is created from.
I realize I may be required to copy the executables over to the target myself, which is fine, but not mentioned in the instructions. I cannot find any definitive list of which built objects should be copied. Most likely, the problem I have here is not specific to oprofile or uClinux, but is just general confusion about Linux's build system - but if somebody here has had the same problem, they may be able to shed light.
Any help much appreciated.
Cheers, John
