Have there been any modifications/additions in the Serial Port (SPORT) registers on BF60x processors?
Question asked by Prashant Employee on Mar 26, 2012
The architecture of Serial Ports on BF60x is different than that of previous Blackfin processors. There have been many enhancements as well. Refer
Accordingly major changes have been made in the SPORT registers of BF60x processor to support those modifications.
Below are important points to note about Serial Port registers on BF60x processor (for complete details refer Hardware Reference Manual):
1] SPORT Control register (CTL_x):
The control bits of SPORT_TCR1 (or SPORT_RCR1) and SPORT_TCR2 (or SPORT_RCR2) registers of previous BF SPORT are combined in a single 32-bit register known as SPORT control register (CTL_x).
Like the name suggests, it controls most of the Serial Port settings such as operating mode, serial word length, clock modes, frame sync type etc.
In addition, the SPORT status (SPORT_STAT) register has been removed from BF60x Serial Port register list. The Data Buffer status and error bits are included in this control register (not all bits of that register).
So, you may find this register resembles to Control register of SHARC Serial Port.
A] Channel Enable Bits:
In Previous BF SPORT, the TSPEN (or RSPEN) bit of TCR1 (or RCR1) register enables the module. It also by default enables primary Data channel. The TXSE (or RXSE) bit in TCR2 (or RCR2) register enables the Secondary Data channel and takes effect only when TSPEN bit is set. So, primary Data channel can’t be disabled OR only secondary channel can’t be enabled.
But BF60x serial Port provides separate enable bits for data channels (so there is no redundant module enable bit). Primary Data channel can be controlled by SPENPRI bit; while secondary Data channel can be independent controlled by SPENSEC control bit. Setting one of these bits enables the module to start the serial port operation.
B] Following control bits are same as previous BF SPORT control register bits:
Bit Name
Same as this bit in BF SPORT control register
Function
DTYPE
TDTYPE field in TCR1, OR
RDTYPE field in RCR1
Controls the data format and companding enable
LSBF
TLSBIT bit in TCR1, OR
RLSBIT bit in RCR1
Controls data in LSB bit first or MSB bit first format
SLEN
SLEN field in TCR2
Selects serial word length
ICLK
ITCLK bit in TCR1, OR
IRCLK bit in RCR1
Controls whether serial clock is internally generated or externally supplied.
IFS
IRCLK bit in RCR1
Controls whether frame sync signal is internally generated or externally supplied.
FSR
TFSR bit in TCR1, OR
RFSR bit in RCR1
Selects framed mode or unframed mode of operation.
DIFS
DITFS bit in TCR1
Selects Data-dependent or data-independent frame sync.
LFS
LTFS bit in TCR1, OR
LRFS bit in RCR1
Selects active high or active low frame sync polarity.
LAFS
LATFS bit in TCR1, OR
LARFS bit in RCR1
Selects early frame sync mode or Late frame sync mode.
OPMODE
TSFSE bit in TCR2, OR
RSFSE bit in RCR2
Generates frame sync as normal pulse shape or in LR shape.
Used as operating mode select bit.
CKRE
TCKFE bit in TCR1, OR
RCKFE bit in RCR1
Drive output signals on one edge of the SPORT_CLK; while sample input signals on other edge of the SPORT_CLK
C] Following bits are added to use the enhancements made in the module.
Bit Name
Purpose
RJUST
This bit is used to enable the Right-justified operating mode of serial port
FSED
Selects sensitivity of frame sync as level-sensitive or edge-sensitive
TFIN
Provides Transmit Finish Interrupt (when configured in Transmit DMA mode)
GCLKEN
Enables Gated clock mode
SPTRAN
Configures serial port in Transmit mode or receive mode
D] The following bits has been used as status bits (These bits are read-only)
Bit Name
Purpose
DXSPRI
Primary Data Buffer status
DERRPRI
Primary Data channel Error
DXSSEC
Secondary Data Buffer status
DERRSEC
Secondary Data channel Error
-          The Data Buffer status bits are similar to TXHRE and TXF bits if configured as transmitter OR similar to RXNE when configured as receiver. It provides more details about this Data buffer status by indicating whether it is Empty, Partially Full or Full.
-          The Data Channel Error bits (DERRPRI and DERRSEC) are similar to TUVF (Transmit under-run) when SPORT is configured Transmitter; OR similar to ROVF (Receive overflow) when SPORT is configured as receiver.
-          There is no support for RUVF (receive underflow) or TOVF (Transmit overflow) error bits as it is there in previous BF SPORT. But those bits are irrelevant in BF60x SPORT, as it is either configured as Transmitter or receiver.
2] SPORT Control 2 register (CTL2_x):
Only two bits of this register are valid, which enables the SPMUX logic (enables internal routing of SPORT signals between two halves of SPORT).
-          CKMUXSEL: enables or disables serial clock multiplexing
-          FSMUXSEL: enables or disables Frame sync multiplexing
3] Divisor Register (DIV_x):
The 16-bit TCLKDIV (or RCLKDIV) and TFSDIV (RFSDIV) registers of previous BF SPORT are combined in a 32-bit single register, known as Divisor register (DIV_x).
-          CLKDIV = (SCLK1 / SPORT_CLK ) – 1
-          FSDIV = (number of serial clocks between frame syncs) – 1
4] Error Register:
This register holds the error status bits and it’s interrupt mask bits to trigger SPORT Status Interrupt.
Bit Name
Purpose
DERRPSTAT
Primary Data channel error detected. Same as DERRPRI status bit in CTL_x register, but W1C
DERRSSTAT
Secondary Data channel Error detected. Same as DERRSEC status bit in CTL_x register, but W1C
FSERRSTAT
Premature Frame sync detected (FS error)
DERRPMSK
When set, triggers SPORT status interrupt
DERRSMSK
FSERRMSK
5] Multi-channel Control register (MCTL_x):
The Control bits in SPORT_MCMC1 and SPORT_MCMC2 multichannel configuration registers of previous Blackfin SPORT have been combined into a single 32-bit register, known as ‘Multichannel Control register’ (MCTL_x).
A] Following control bits are same as previous BF SPORT Multichannel control register bits:
Bit Name
Same as this bit in BF SPORT MC register
Function
MCE
MCMEN bit in MCMC2
When set, enables multichannel and packed mode
MCPDE
MCDTXPE and MCDTXPE bit in MCMC2
When set, enables Multichannel DMA Packing
MFD
MFD field in MCMC2
Determines multichannel frame delay
WSIZE
WSIZE field in MCMC1
Determines window size. (different compared to WSIZE field calculation in BF SPORT)
WODFFSET
WOFF field in MCMC1
Determines window offset
B] The Following bits of SPORT_MCMC2 register has been removed from BF60x serial port:
-          MCCRM : 2X Clock Recovery Mode
-          FSDR : Frame sync to Data Relationship (H.100 mode)
6] Multichannel Select Registers (CSn_x):
In previous BF SPORT, the SPORT_MTCSn (Multichannel Transmit Select) and SPORT_MRCSn (Multichannel Receive Select) registers are used to select channels for Tx and Rx side.
In BF60x, since a serial port can be either configured as transmitter or receiver, the two groups of registers are replaced with a single group known as SPORT_CSn (where n=0,1,2,3). Usage of register is same.
7] Multi-channel Status Register(MSTAT_x):
The SPORT_CHNL register in the previous BF SPORT has been renamed as MSTAT_x, known as multichannel status register. It indicates the current multi-channel being serviced.
8] Data Buffer Registers (TXPRI, TXSEC and RXPRI, RXSEC):
Although BF60x SPORT can be configured as either transmitter or receiver, it incorporates separate Transmit Data buffer and Receive Data buffer for each Primary and Secondary Data channels. But only one type of buffers (TX or RX) are active as per enabled data channels. Programmer must not attempt to access the inactive buffers.
Additional Notes:
-          All registers are 32-bit wide.
-          Each SPORT half have it’s own registers (i.e. there is not a single register which is shared between the SPORT halves).
-          The naming of registers is SPORTnumber_Registername_SPORThalve.
               e.g. Serial Port control register of SPORT1_B serial port is denoted as SPORT1_CTL_B;
-      when using Crosscore IDDE, the header files of processor attaches REG before the register name. So, this register can be find as REG_SPORT1_CTL_B in the header file.
