Interfacing AD7730 to PIC 16F877
Question asked by swasthika.manaram on Mar 24, 2012
Latest reply on Oct 30, 2012 by TejaN
Dear All,
I'm doing a project of interfacing AD7730 with PIC16F877.
I am successfully communicating with internal registers of AD7730, but the problem is when I am going to read the data register it is showing only 0.
And RDY pin is not going to low, that to indicate new data is available.
Then I put some break points in codes and found that when I give the command to internal calibration, it is not performing.
Because if it is performing it should reset the Mode registry first three bits to 000, in my case all the time it is showing my last command only.
I used 5V for excitation and power-up the IC
ref+ and ref- are supplied same as VDD and VGND, and after voltage regulator 7805 , it is supplying 4.96V to those pins.
crystal oscillator for AD7730 is 4.952MHz ,and 15pF capacitors are fixed.
my load cell is 10mV full range with 5V excitation.
Procedure I used is
Write to the filter register first.
Then write to the Mode register for calibration.
Pls help me
  adc_write_byte(3);//Filter
   adc_write_byte(16);//00010000
    adc_write_byte(3);//00000011
     adc_write_byte(0);//00000000
         adc_write_byte(2);//Mode Internal full scale calibration
         adc_write_byte(176);//10110000
         adc_write_byte(128);//10000000
This adc_write_byte function was developed by myself and by writing and after reading same registry I found that communication is perfectly working.
