Unexpected USB wake-up from hibernate
Question asked by jeremie on Mar 16, 2012
Latest reply on Mar 23, 2012 by jeremie
Can you help me: I have unexpected hibernate wake-up due to USB. Thanks!
My configuration:
-BF548.0.2
-custom board; the USB HW part is a copy-paste from the EZKIT
-USB Type B (peripheral)
My problem: the core  wakes up (for USB reason: I check PLL_STAT bits) while no USB is plugged.
Different tries:
A) During hibernate, the 24MHz is kept on; before entering hibernate, CSR_HBR (APHY2) is set. After about 0.5s of hibernate, the core wakes up for USB reason.
B) During hibernate, the 24MHz is OFF; before entering hibernate, CSR_HBR (APHY2) is set. After about 0.5s of hibernate, the core wakes up for USB reason.
C) During hibernate, the 24MHz is OFF; before entering hibernate, CSR_HBR (APHY2) is NOT set. After about 1s of hibernate, the core wakes up for USB reason.
***** BUT *****
D) During hibernate, the 24MHz is kept on; before entering hibernate, CSR_HBR (APHY2) is NOT set. The core does not wake-up. The problem is the extra power consumption due to the 24MHz, which I want to avoid.
E) In situation A and C (I have not tried for B), if I put 100k external pull-down resistors on D+ and D-, the core does not wake-up. The problem is that it is not specified any need of such pull-down (and which value), so this is not satisfying as is.
Thanks for your help!
