AD9834: how to implement DPSK Modulation
Question asked by nerbone85 on Mar 13, 2012
Latest reply on Mar 16, 2012 by nerbone85
Hi all,
I need an help to implement DPSK modulation: if I read a 0, phase changes of 180 degree, otherwise the phase is the same of the previous.
I'd like to use always bit control...so I have a question: how many clock cycles do I have to wait for seeing change of phase?
This is my code to implement DPSK modulation...what do you think about this? How can I test if it's all right?
#include <avr/io.h>
#define F_CPU 8000000UL
#include <util/delay.h>
#include <avr/interrupt.h>
//-----------------------------clock generation----------------------------//
/* si vuole una frequenza di 4 MHz */
void set_adMCLK(void) {
    DDRD = 0x60;    // si usa la porta OC1A come uscita pin 19
    TCCR1B |= (1 << WGM12);     // si imposta il Timer1 in modo CTC (su OCR1A)
    OCR1A = 0;
    TCCR1A |= (1 << COM1A0);    // si imposta il toggle su OC1A
    TCCR1B |=(1 << CS10);    // prescaler di 1
//-----------------------------------SPI-----------------------------------//
#define DDR_SPI    DDRB
#define DD_MOSI    DDB5
#define DD_SCK    DDB7
#define DD_CS    DDB4
void SPI_MasterInit(void)
   DDR_SPI = (1<<DD_MOSI)|(1<<DD_SCK)|(1<<DD_CS);
   SPCR = (1<<SPE)|(1<<MSTR)|(1<<SPR1) |(1<<CPOL);
void SPI_Begin(void)
    PORTB &= ~( 1 << DD_CS);
void SPI_End(void)
    PORTB |= 1 << DD_CS;
void SPI_Set(void)
void SPI_MasterTransmit(char cData)
   SPDR = cData;
   while (!(SPSR &(1<<SPIF)));
void spi_ad_16(unsigned short data) {
    unsigned char MSdata = ((data >>8) & 0x00FF); // bit più significativi
    unsigned char LSdata = (data & 0x00FF); // bit meno significativo
    SPDR = MSdata; // invia i primi 8 bit più significativi
    while(!(SPSR & (1<<SPIF))); //ciclo attesa
    SPDR = LSdata; // invia gli ultimi 8 bit meno significativi
//-----------------------------------END SPI--------------------------------------------//
//-----------------------------------INITIALIZATION PHASE 0-----------------------------//
void phase0(void) {
    SPI_Begin();
              spi_ad_16(0x2100);     // parola di controllo, uscita settata a mezza tensione
    SPI_End();
            _delay_us(300);
    SPI_Begin();
            spi_ad_16(0x5EB8);  // MSB del registro FREQ0
    SPI_End();
            _delay_us(300);
    SPI_Begin();
            spi_ad_16(0x4014);    // LSB del registro FREQ0
    SPI_End();
            _delay_us(300);
    SPI_Begin();
            spi_ad_16(0xC000); // phase offset di 0°   phase register0
    SPI_End();
        _delay_us(300);
    SPI_Begin();
            spi_ad_16(0xE800);  // phase offset di 180° phase register1
    SPI_End();
            _delay_us(300);
    SPI_Begin();
            spi_ad_16(0x2000);
    SPI_End();
          _delay_us(300);
//-----------------------------------END PHASE 0--------------------------------------------//
//-----------------------------------INITIALIZATION PHASE 1---------------------------------//
void phase1(void) {
    SPI_Begin();
              spi_ad_16(0x2500);     // parola di controllo, uscita settata a mezza tensione
    SPI_End();
            _delay_us(300);
    SPI_Begin();
    SPI_End();
            _delay_us(300);
    SPI_Begin();
    SPI_End();
            _delay_us(300);
    SPI_Begin();
    SPI_End();
        _delay_us(300);
    SPI_Begin();
    SPI_End();
            _delay_us(300);
    SPI_Begin();
            spi_ad_16(0x2400);
    SPI_End();
          _delay_us(300);
//-----------------------------------END PHASE 1--------------------------------------------//
int main(void) {
    DDRA=0b01010101;
    int dato;
    DDRC |= (1 << DDC0);
    set_adMCLK();
    SPI_Set();
    _delay_us(3000);
    SPI_MasterInit();
    for (int i=0; i<8; i++) {
        dato = DDRA;
        if(dato & (0b00000001) == 1) {
                PORTC |= (1 << PC0); // accendi il led
                _delay_us(200000);
                phase0();
        else {
                PORTC = 0x00;
                _delay_us(200000);
                phase1();
        DDRA = DDRA >>1;
    while(1){}
..thanks to all! :-)
