Best practices for partitioning MTD
Question asked by halm on Mar 9, 2012
Latest reply on Mar 12, 2012 by Aaronwu
This is similar to http://ez.analog.com/thread/12095 ... but not quite.
I have nor flash and I've tried to lay out the partitions as follows:
static struct mtd_partition cm_partitions[] = {
        {       /* mtd0: 0x20000000 - 0x2003ffff */
                .name   = "bootloader(nor)",
                .size   = 0x40000,
                .offset = 0,
        }, {    /* mtd1: 0x20040000 - 0x2017ffff */
                .name   = "uclinux safe kernel(nor)",
                .size   = 0x140000,
                .offset = MTDPART_OFS_APPEND,
        }, {    /* mtd2: 0x20180000 - 0x201dffff */
                .name   = " safe linux filesystem(nor)",
                .size   = 0x60000,
        }, {    /* mtd3: 0x201e0000 - 0x2035ffff */
                .name   = "uclinux kernel(nor)",
                .size   = 0x180000,
        }, {    /* mtd4: 0x20360000              */
                .name   = "primary file system(nor)",
                .size   = MTDPART_SIZ_FULL,
The idea is that the safe kernel and it's filesystem would be read only, and booted to only in an emergency.  The last 2 partitions are for normal operation.
First of all, is this a reasonable expectation?
Next, I don't understand this:
bfin> tftp 0x1000000 rootfs.jffs2-safe
Using bfin_mac device
TFTP from server 10.1.2.56; our IP address is 10.1.2.24
Filename 'rootfs.jffs2-safe'.
Load address: 0x1000000
Loading: #################################################################
done
Bytes transferred = 1835008 (1c0000 hex)
I've defined the partition to be 0x60000, and yet the transfer is 0x1c0000.   This messes up my offset calculations when copying to flash.
There's something going on here that I don't understand.
Depending on how I copy to flash (using the sizes I expect or the sizes I observer on download) I either fail unable to find a kernel image (in the former case) or something like this in the latter.
CPU:   ADSP bf516-0.2 (Detected Rev: 0.2) (parallel flash boot)
__ADSPBF516__ not defined
Board: iMix Dev Board
       Support: http://www.loudtechinc.com
gpio_cfi_flash_init()
Clock: VCO: 400 MHz, Core: 400 MHz, System: 100 MHz
RAM:   32 MiB
Flash: 32 MiB
In:    serial
Out:   serial
Err:   serial
KGDB:  [on serial] ready
Net:   bfin_mac
Hit any key to stop autoboot:  0
## Booting kernel from Legacy Image at 20040000 ...
   Image Name:   bf516-0.2-2.6.37-ADI-2011R1-pre
   Created:      2012-03-09   5:28:15 UTC
   Image Type:   Blackfin Linux Kernel Image (gzip compressed)
   Data Size:    1003947 Bytes = 980.4 KiB
   Load Address: 00001000
   Entry Point:  001b78a0
   Verifying Checksum ... OK
   Uncompressing Kernel Image ... OK
Starting Kernel at = 001b78a0
Linux version 2.6.37-ADI-2011R1-pre (halm@wdn-halm-linux) (gcc version 4.3.5 (AD
I-2010R1-RC4) ) #755 Thu Mar 8 21:28:14 PST 2012
register early platform devices
Board Memory: 32MB
Kernel Managed Memory: 32MB
Memory map:
  fixedcode = 0x00000400-0x00000490
  text      = 0x00001000-0x00142150
  rodata    = 0x00142150-0x001859d0
  bss       = 0x00186000-0x0019ab44
  data      = 0x0019ab44-0x001b0000
    stack   = 0x001ae000-0x001b0000
  init      = 0x001b0000-0x001ce000
  available = 0x001ce000-0x01f00000
  DMA Zone  = 0x01f00000-0x02000000
Hardware Trace Active and Enabled
Boot Mode: 1
Blackfin support (C) 2004-2010 Analog Devices, Inc.
Compiled for ADSP-BF516 Rev 0.2
Blackfin Linux support by http://blackfin.uclinux.org/
Processor Speed: 400 MHz core clock and 100 MHz System Clock
NOMPU: setting up cplb tables
Instruction Cache Enabled for CPU0
  External memory: cacheable in instruction cache
Data Cache Enabled for CPU0
  External memory: cacheable (write-back) in data cache
Built 1 zonelists in Zone order, mobility grouping off.  Total pages: 7874
Kernel command line: root=/dev/mtdblock2 rw rootfstype=jffs2 clkin_hz=25000000 e
arlyprintk=serial,uart0,115200 console=ttyBF0,115200
PID hash table entries: 128 (order: -3, 512 bytes)
Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
Memory available: 29568k/32768k RAM, (120k init code, 1284k kernel code, 440k da
ta, 1024k dma, 332k reserved)
NR_IRQS:159
Configuring Blackfin Priority Driven Interrupts
Console: colour dummy device 80x25
console [ttyBF0] enabled
Calibrating delay loop... 780.28 BogoMIPS (lpj=390144)
pid_max: default: 32768 minimum: 301
Mount-cache hash table entries: 512
Blackfin Scratchpad data SRAM: 4 KB
Blackfin L1 Data A SRAM: 16 KB (16 KB free)
Blackfin L1 Data B SRAM: 16 KB (16 KB free)
Blackfin L1 Instruction SRAM: 32 KB (26 KB free)
NET: Registered protocol family 16
Blackfin DMA Controller
iMix_init(): registering device resources
bio: create slab <bio-0> at 0
bfin-spi bfin-spi.0: Blackfin on-chip SPI Controller Driver, Version 1.0, regs_b
ase@ffc00500, dma channel@7
i2c-bfin-twi i2c-bfin-twi.0: Blackfin BF5xx on-chip I2C TWI Contoller, regs_base
@ffc01400
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 1024 (order: 1, 8192 bytes)
TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
TCP: Hash tables configured (established 1024 bind 1024)
TCP reno registered
UDP hash table entries: 256 (order: 0, 4096 bytes)
UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
debug-mmrs: setting up Blackfin MMR debugfs
JFFS2 version 2.2. (NAND) (SUMMARY)  ▒© 2001-2006 Red Hat, Inc.
msgmni has been set to 57
io scheduler noop registered (default)
bfin-otp: initialized
bfin-uart: Blackfin serial driver
bfin-uart.0: ttyBF0 at MMIO 0xffc00400 (irq = 29) is a BFIN-UART
brd: module loaded
gpio-addr-flash: probing 16-bit flash bus
gpio-addr-flash: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x00
0001 Chip ID 0x002201
Amd/Fujitsu Extended Query Table at 0x0040
  Amd/Fujitsu Extended Query version 1.3.
number of CFI chips: 1
cmdlinepart partition parsing not available
RedBoot partition parsing not available
gpio-addr-flash: Using board partition definition
Creating 5 MTD partitions on "gpio-addr-flash":
0x000000000000-0x000000040000 : "bootloader(nor)"
0x000000040000-0x000000180000 : "uclinux mini kernel(nor)"
0x000000180000-0x0000001e0000 : "mini-linux filesystem(nor)"
0x0000001e0000-0x000000360000 : "uclinux kernel(nor)"
0x000000360000-0x000002000000 : "primary file system(nor)"
bfin_mii_bus: probed
bfin_mac: attached PHY driver [Generic PHY] (mii_bus:phy_addr=0:01, irq=-1, mdc_
clk=2500000Hz(mdc_div=19)@sclk=100MHz)
bfin_mac bfin_mac.0: eth0: Blackfin on-chip Ethernet MAC driver, Version 1.1
rtc-bfin rtc-bfin: rtc core: registered rtc-bfin as rtc0
i2c /dev entries driver
bfin-wdt: initialized: timeout=20 sec (nowayout=0)
TCP cubic registered
rtc-bfin rtc-bfin: setting system clock to 1970-01-01 00:00:00 UTC (0)
dma_alloc_init: dma_page @ 0x011b3000 - 256 pages at 0x01f00000
jffs2: Too few erase blocks (3)
List of all partitions:
1f00             256 mtdblock0  (driver?)
1f01            1280 mtdblock1  (driver?)
1f02             384 mtdblock2  (driver?)
1f03            1536 mtdblock3  (driver?)
1f04           29312 mtdblock4  (driver?)
No filesystem could mount root, tried:  jffs2
Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,2)
Stack info:
SP: [0x0101bf24] ▒▒
Memory from 0x0101bf20 to 0101c000
0101bf20: 00000000 [0015357c] 001408ac  01084006  0015357c  0018b4bf  0018b4bf
0018b4bf
0101bf40: 0101bf6c  00191e40  001b0a60  01084006  01084000  001c4e1c  0101bf7c
00153488
0101bf60: 00000000  00000000  00000032  0101bf7c  0101bf7c  00008000  00000000
6e6b6e75
0101bf80: 2d6e776f  636f6c62  3133286b  0029322c  001b0b0e  00186068  00001f02
00000000
0101bfa0: 001b0c40  00186068  001c4dd4  00000000  00000000  00000000  00000000
001b01d2
0101bfc0: 001cb2fc  001cb2fc  00000000  00000000  001b01e6  001cb2fc  001cb2fc
00000000
0101bfe0: 00000000  00000000  00001576  00000000  00000000  00000000  ffffffff
00000006
Return addresses in stack:
